Well motors out and disassembly has begun..
Old Apr 10, 2005 | 08:23 PM
LoudmouthSS's Avatar
Well Yesterday i finally got the engine out...god im never gunna remember where all those wires go ...even with the millions of pictures i took. Anyway today i unmounted the tranny and go the engine on the engine stand. Then i began tearing into the motor itself. Well i knew the guy had done his own port job to the heads, so i was nervous about the way they'd look..well heres some pictures...idk, i dont think it looks to good, looks like it gets alittle thin in spots..and some carbon was between the ports..and i dont think thats good right?...like carbon was between that...slither of metal between the ports. Well anyway here are the pictures...you think there saveable?
http://memimage.cardomain.net/member...61_60_full.jpg
http://memimage.cardomain.net/member...61_61_full.jpg
http://memimage.cardomain.net/member...61_62_full.jpg
http://memimage.cardomain.net/member...61_63_full.jpg
Also whats the best way to remove the heads? I was just going to take them off as a hole..but my dad said something bout the marking off the position of something??
Old Apr 10, 2005 | 08:54 PM
TheGreatJ's Avatar
Re: Well motors out and disassembly has begun..
That's a pretty crummy looking port job. The ports aren't even and the sides aren't straight, there's no way they can match the gasket openings, and that one pair in the second shot looks like he rounded off the divider between the ports. That can cause uneven fuel distribution to those two cylinders if the intake gasket doesn't seal.
They're probably useable, but if I were building a motor that was anything more than mild I'd find another set and do a better (cleaner) port job on them.
Old Apr 10, 2005 | 10:02 PM
Yea i figured I wouldnt hear anything good about it. Hmm well this builds on a budget so i dont wanna go crazy and buy performance heads. Well..do you think a machine shop could possibly fix this problem?
Old Apr 11, 2005 | 12:54 AM
Nitro's Avatar
Cool Re: Well motors out and disassembly has begun..
I think a machine shop can fix it go ahead find out what that shop says
alex5366
Mar 27, 2015 03:30 PM
transam_388
Mar 15, 2015 11:53 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
