Dropping in some FI
Old Apr 8, 2005 | 06:50 PM
ChrisUlrich's Avatar
Dropping in some FI
Couldn't I just change my rotating assembly and rop the compression to ets say... 8 1/2 - 9 to 1 Compression? Drop in a supercharger for a nice/safe/powerful engine? I already have a brand new valvetrain, just stock heads... but they are going to be ported by LE.
The fuel system would be upgraded, but it wouldn't be at the same time.
Old Apr 9, 2005 | 02:41 PM
Valkyn71's Avatar
Re: Dropping in some FI
Yes, if you dont get crazy with the boost.
I'd say around 450 RWHP? Not sure what the stock crank and rods can hold up to.
Old Apr 9, 2005 | 10:05 PM
So if I change my rotating assembly, I should be able to handle 10psi safely?
Old Apr 10, 2005 | 05:38 PM
MEAN LT1's Avatar
Just 10psi you say?, just by you dropping the compression down will allow you to run that with no problem. the key for your setup to last will be tuning, but then again that the key along with part to anybodys setup to last.
Old Apr 10, 2005 | 07:36 PM
So for like 1500 in parts I can run more then 10psi? haha
I was going to go scat9000, I beam rods, and JE pistons...
what else you think I should do?
Old Apr 10, 2005 | 11:40 PM
1982z28with18s's Avatar
Good luck rebuilding it for $1500. All the little stuff adds up quick.
machine work
balancing
gaskets
bolts
rings
bearings
etc
Old Apr 11, 2005 | 12:55 PM
Really? How much does a bottom end rebuild usually cost? I don't think I am going to have it bored/honed if I don't have too. Just the rods/crank/pistons for the forged crap and dropping the compression. What does that typically cost/involve?
Old Apr 11, 2005 | 03:28 PM
Leedogg 96TA's Avatar
If you aren't gonna stroke it- don't worry about the crank...the factory crank is good for over 500 rwhp(got a friend that made 625 on the bottle on a stock crank and it never failed). Do some good I or H beam rods and a set of forged slugs and you'll be good to go.
I am running a Scat 9000 in my 383 with eagle I beams and SRP forged piston.- I only plan to drop in some lower compression JE pistons when I do my SC- and I am looking for the 12-14 psi range(looking for 600 at the wheels(doubtful but i can wish).
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
kandied91z
Sep 30, 2015 11:43 PM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
