Part Number for Front Caliper Bolt
Old Apr 7, 2005 | 06:30 PM
WestCoast96Z28's Avatar
Does anyone know the p/n for the caliper bolt for the LS1 front brakes? Not the banjo bolt...the bolt that mounts the calipers to the spindle.
Old Apr 7, 2005 | 06:49 PM
stereomandan's Avatar
Re: Part Number for Front Caliper Bolt
Do you mean the bolt that mounts the abutment bracket to the spindle?
Dan
Old Apr 7, 2005 | 07:47 PM
Z28barnett's Avatar
Might be 18023646, I can't tell for sure. These are, I think, the larger bolts that do not go into the guide pins, they hold the cage like bracket to the steering knuckle and do not go into the caliper itself.
GM PART # 18023646
CATEGORY: Wheel Brake Cylinder/Caliper
PACK QTY: 5 CORE CHARGE: $0.00
GM LIST: $4.09
OUR PRICE: $2.33
DESCRIPTION: BOLT
Guide pin bolts are.
GM PART # 18026153
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $17.31
OUR PRICE: $8.66
DESCRIPTION: BOLT
Best to check with a partsman, if they have them in stock easy to compare. The guide pin bolts are 8mm.
Z28
Old Apr 7, 2005 | 10:28 PM
Guidepin bolts are the ones that slide into the caliper. They don't bolt the caliper to the spindle. It must be the other ones you have listed, but I don't know for sure if that's the right part #.
Dan
Old Apr 8, 2005 | 05:05 PM
Yeah..it's the first one I need. Not the guide pins, but the ones that mount the caliper brackets (cage) onto the spindles. Meaing, if you were to remove the entire caliper assembly fromt he spindle...these are the 2 that need to be taken out. Thanks for the p/n, and I'll confirm with a dealership before ordering them.
Old Apr 8, 2005 | 05:11 PM
Sounds good. That cage is called the abutment bracket.
Dan
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
