Complete LT1 too LS1 Brake Swap
Old Apr 5, 2005 | 10:07 PM
ChrisUlrich's Avatar
I bought LS1 Calipers, Rotors, and brackets... I was wondering if I needed the spindles, knuckle, brake lines, and master cylinder to make this swap complete. Just the front brakes are being swapped... not the rear.
Old Apr 5, 2005 | 10:31 PM
Bow94z's Avatar
Re: Complete LT1 too LS1 Brake Swap
yup you need the spindles. they are different. LT1/LS1 are the same hubs and the LT1 lines could be used with some provisions. LS1 lines are a little better but still are tight
Check this out. http://www.fbody.com/tech/details.cgi?id=30
and http://www.fbody.com/tech/details.cgi?id=29
Good luck
Old Apr 6, 2005 | 01:13 AM
madwolf's Avatar
I reused my stock brake lines. Work fine. Just had to bend their holding bracket a bit.
As already mentioned, you will need the spindles.
Old Apr 7, 2005 | 05:36 PM
white97T/A's Avatar
I just did this swap a few weeks ago.. and a couple of notes
I have never removed spindles/knuckles prior to this job before, and according to all of the articles that I read prior to doing this, everyone said that you can just use a large hammer to remove the spindles.
my own expieriece was that after trying a hammer for 3 hours, I still did not have either one of the spindles off, I went to autozone and bought a couple of "pullers" and then had the spindles off in 10 minutes.. my advice is to go get a couple of different size pullers before starting this job.
other than that, you may also need some new copper seals for where the brake lines connect to the caliper, I couldn't get mine to stop leaking until I put new seals in.
finally, my stock brake lines are fine with no modification to the "brackets" as you will see mentioned a lot... I have a '97 though .. not sure if it matters.
good luck
ddr698
Jan 9, 2015 10:05 AM
Jazsun
Dec 29, 2014 12:14 PM
vals95z
Mar 18, 2003 03:45 PM
