Question on weight loss in a 3rdgen LT1 swap?
Old Apr 5, 2005 | 05:16 PM
MeanGreen97Z's Avatar
Arrow Question on weight loss in a 3rdgen LT1 swap?
I plan on pull ALL A/C equipment and emissions equipment. I will be putting in a set of SLP headers and y pipe with a high flow cat. I also will be changing to a T56. No back seats with sparco front seats, Grant GT steering wheel, no spare or jack, and pin on harwood hood. I figure on 200lbs of weight loss with the LT1 and all the lighter better quality parts I am replacing on the car. Does this sound about right? Anyone know normal weight for a 88 Camaro SC with a auto tranny, 305, and almost no options?
Old Apr 5, 2005 | 11:05 PM
respectirocz's Avatar
Re: Question on weight loss in a 3rdgen LT1 swap?
my 87 iroc with 305 4bbl manual tranny t-tops says around 3400 on the title
Old Apr 7, 2005 | 01:10 PM
Nitro's Avatar
Cool Re: Question on weight loss in a 3rdgen LT1 swap?
If your trying to find out the weight of your car then just look at your car's title it should say it there
Old Apr 7, 2005 | 01:32 PM
how does an lt1 shave off 200 lbs?
it is to my understanding that an ls1 block weighs 100 lbs less than a standard small block because its made of aluminum
Old Apr 7, 2005 | 02:19 PM
With the addition of the lighter LT1, no A/C stuff, much lighter exhaust, no back seats and sparco fronts, lighter steering wheel, no spare or jack, and pin on fiberglass hood I figured 200 lbs was an easy acheivement. You think otherwise?
Old Apr 7, 2005 | 11:03 PM
i think all of those may be over 200, your original statment sounded like u meant the lt1 alone was good for 200 lbs
all those items u mentioned sounds around 250 lbs to me
Old Apr 7, 2005 | 11:21 PM
92RS305#2's Avatar
a/c alone is about 75lbs if you get every little piece including the evaporator.
Old Apr 8, 2005 | 01:53 PM
CustomSSI's Avatar
Hey meangreen I PMed you back about those headers.
Josh
Old Apr 13, 2005 | 03:30 PM
I PM'd back. Is the collector 3"? LOL
250lbs sounds good.
oldschool
Feb 9, 2016 09:21 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
bossco
Nov 29, 2014 10:18 AM
Jul 4, 2005 05:00 PM
