Computer Swap
Old Apr 5, 2005 | 06:58 AM
SS#771's Avatar
Computer Swap
Alright so i am swapping over to OBD1...had a resistor put in the computer so the knock sensors will read correctly. I put the computer in tonite (still needs tune) but when it runs for about 20 seconds the fan turns on as normal then goes nuts and instanly doubles speed. I do have an electric water pump and my fan did rub on some things at one time....but i did not do this until i switch the computers tonite. So will the tune fix this or is something else wrong?
Old Apr 6, 2005 | 06:29 PM
97Z-M6's Avatar
Re: Computer Swap
in the constants table there are temp settings that enable low fan speed and high fan speed sounds like you ser them the same and the high speed setting is being enabled to early, set them about 10 degrees C different.
IgorT.455/406
Mar 12, 2015 03:39 AM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
