intake hose colapses under wot on ati w/ twin i/cooler
Old Apr 2, 2005 | 08:02 PM
bluelt1z28's Avatar
I have an 8 psi ati p1sc with twin intecoolers and at wot at about 6psi of boost the intake hose colapses. Are there any fixes for this or do I have to do hard tubing
Old Apr 2, 2005 | 08:44 PM
agrsiv95's Avatar
Re: intake hose colapses under wot on ati w/ twin i/cooler
I had the same problem but it didn't start happening until was in the teens for boost, so I welded up a hard tube. If your using the supplied orange hose with the wire inside it may be stretched out to much and not enough wire to support it.
J
Old Apr 2, 2005 | 09:48 PM
Alvin@pcmforless.com's Avatar
http://stahlheaders.com/Frame%20Tubing.htm
Go there, You can find everything you need for a hard tube intake. I would think that the only other possiblity is that the filter is too dirty.
Old Apr 2, 2005 | 10:21 PM
Jeff 96 SS's Avatar
Hard tubing is always a good idea but at your boost level My advice would be to take some measuments and install the biggest damn filter you can possible fit on that thing.
Jeff
96 SS BLOWN
96 TA 396 D1
Old Apr 3, 2005 | 06:11 AM
rskrause's Avatar
Moderator
That orange dryer hose SUCKS (no pun). I kept replacing pieces of it until eventually I had a complete hard intake.
Rich
Old Apr 3, 2005 | 11:56 AM
slimdawson's Avatar
Yep, go hard intake and don't look back. Good investment.
Old Apr 3, 2005 | 08:34 PM
bluelt1z28's Avatar
Does anybody have any pics of hard tubing on their car?
Old Apr 3, 2005 | 11:53 PM
slimdawson's Avatar
Check my sig link.
Old Apr 4, 2005 | 09:06 AM
David94TA's Avatar
I found a great tubing here that is much stronger than the original dryer vent tubing but is still flexible enough to make the curve. The reinforcing wire is closer together and the material is much tougher. It is called Sil-Tech exhaust tubing (not sure if the spelling is right). I bought it at Chattanooga Rubber and Gasket Co. It is about $10/ft but that is still much less than having to fab up a hard intake. In the interest of helping out and sharing a good thing, I've got a couple of small pieces left over that I would be willing to send to a couple of you guys to look at to see if you agree with me. I seriously doubt that you will collapse this tubing. Just shoot me an e-mail and put "intake tubing" in the subject line.
Jun 6, 2015 08:27 AM
Red_94Formula
Mar 7, 2015 09:21 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
