Shifts with no clutch pedal depression?
I have done some searching and found lots of folks with Spec clutches have high pedal engagement. It is very annoying but after about 1000 miles on my spec 4 setup, it hasn't slipped and am I getting ready to dyno it today with alot of nitrous. So I will see if it slips or not.
My question has to do with shifting without using the clutch. After I take off from a stop in first, I don't have to touch the clutch pedal again in order to shift through the gears. I can even downshift from say 6th to 5th if a rev it a bit.
In other words my T56 is acting just like a big rig diesel does.
Are any of you able to do this. I am not sure if it is a problem because my mustang was able to do the same thing. I have a CDL license, and have driven big rigs for a while, so everytime I get in a vehicle that has a manual tranny I check to see if I can shift without the clutch.
Is this normal?
Is this normal?
Re: Shifts with no clutch pedal depression?
The trannies have synchros, so yeah, you can shift without clutching
. I've shifted our '73 that way, and even my old '96 Sunfire 5-speed!!
Just my opinion on that spec clutch.. your not going to get it to slip.. I have the same clutch in my car.. Doesnt last very long but its very very strong. Next clutch im getting though is a mcloud.. They seem to have alot longer life.
stangspank
Nov 13, 2015 01:02 PM
