From Automatic to Standart
Old Mar 30, 2005 | 12:38 PM
LarsUngerer's Avatar
I'm thinking about switching my automatic tranny with a standart and just wanted to know what parts i need to do so i haven't bouhgt a tranny yet.
I'm still debating if i should gte a 4 or a 5 speed?
Would a 5 speed fit?
And where could i take a tranny out like could i take it out of other vehicles other then a camaro?
Really appreciate your help.
Old Mar 30, 2005 | 04:16 PM
jg95z28's Avatar
Re: From Automatic to Standart
If money is no object, this'll make your life easier...
http://www.keislerauto.com/gm/camaro.html
Old Mar 30, 2005 | 05:04 PM
I'm kinda tight on budget i would like to spend around the $400 to $700 on a transmission so i have to get a used one and thought if other tansmission out of a chevy truck or another chevy cars would fit in to my '80 camaro?
and what else would i need for it?
Thanks for he reply really appreciated it please keep them coming.
Old Mar 30, 2005 | 08:30 PM
Dave89IROC's Avatar
try to find a 2nd gen f-body in the J/Y with a 4 speed, and grab everything you need, I don't know where you are located, but if you have to grab the trans from behind a pontiac/olds/buick motor, the flywheel and bellhousing will be different
Old Apr 2, 2005 | 05:40 PM
catwalk's Avatar
I converted an '80 Vette to standard tranny last year. The work required can be extensive, but the major parts are few:
-Standard tranny (obviously)
-Flywheel
-Brake and Clutch Assembly
-Clutch plate and pressure plate
-Crossmember or Crossmember Mount, depends on the car
-Bellhousing and Clutch Fork
-Drive Shaft (In some conversions, the manual shaft is longer)
-Gear Shifter Bracket and Gear Shifter
-Pilot Bearing for the backside of the crankshaft
-Throw-out Bearing for the clutch fork
-Z-Bar and Z-Bar pivoting ball that screws into the block
-Z-Bar Bracket for securing Z-Bar to chassis ( if not already there)
-All the necessary rods and springs the clutch pedal and Z-Bar
-Inner and Outer Shifter Boots
Old Apr 4, 2005 | 11:01 AM
IRONFIST's Avatar
You can get everything you need from a donor car....
Lotsa work though, don't know if it would really be worth it.
Old Apr 4, 2005 | 01:06 PM
Would it be possible toput a 5 speed from a newer model like a 85 or a 90 or somehtign like it into my '80 or r they built different?
Or could i just get diferent brakets in or so?
Old Apr 10, 2005 | 05:33 PM
I found a 5 speed tranny from a '85 camaro and just wanted to find out if i can put it in my '80 befor i'm gonna buy it, or if i would need a different bell houseing or so ?
I hope i could get an awnser soon.
Old Apr 10, 2005 | 05:46 PM
Dave89IROC's Avatar
the bellhousing in the third gens(82-92) tilt the trans(13 degrees?) and the second gens(70-81) need it strait up
Old Apr 11, 2005 | 09:27 PM
If my '80 needs it straight up and the '85 tranny is tilted could i cange the bellhousing or wouldn't that work? or is there any way to make it fit??
Really appreciate ur feed back!!
Old Apr 11, 2005 | 11:39 PM
Dave89IROC's Avatar
yeah, change the bellhousing, should work, someone has probably done it, search for T5 into an 80
Old Apr 12, 2005 | 07:33 PM
Greed4Speed's Avatar
The GM T5 is weak. thats why it was only put with the 305.
For your budget get a nice converter etc for your auto, if you're into drag racing.
WobblySausage
Oct 7, 2015 10:09 AM
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
