New Baer front rotors or GT+
Old Mar 30, 2005 | 07:26 AM
00 SS's Avatar
I am considering between new Baer Eradispeed front rotors or getting the Baer GT+ front brake system?
Is the GT+ system worth the extra money? How much more performance can I expect. I go to open lapping day at the local road course about 2-3 times per year.
Old Mar 30, 2005 | 10:10 AM
stereomandan's Avatar
Re: New Baer front rotors or GT+
Only issue with keeping your current setup is if you are getting "spread" calipers. Is the contact of the pad to rotor staying pretty even during your track days? If it is, then I would just get good pads and the Eradispeed rotors. If your calipers are spreading, then look to a better brake setup like the GT+.
Dan
Old Mar 30, 2005 | 10:37 AM
00 SS's Avatar
I should have said I plan on going to open lapping day 2-3 times this year. I just got the car last summer and have not had the oppurtunity to take it to the track yet.
I am not sure what you mean by spread calipers. I know the stock rotors will not hold up at the track since I had to get them machined when I bought the car.
I imagin you noticed a big difference going from stock lt1 rotors to the c5 brakes (which I undersand are basically the same as the gt+ 13.15" setup).
Has anyone gone from 12" rotors with stock calipers to the 13.15" gt+ setup? How much difference did it make?
Or did anyone just swap stock rotors with eradispeed rotors? Make a difference?
Old Mar 30, 2005 | 12:16 PM
Personally, I don't think I'll ever put a lot of money into rotors. Even the best rotors can warp. The benefit of the two piece rotor(eradispeed) is less weight, and less heat to your bearings. Your car is going to stop the same whether or not it's a two piece rotor.
Caliper spreading is when the forces and heat are so strong on the caliper that the inside edge(closest to center of rotor) of the caliper and pad don't put as much force on the rotor. Basically, the force you are trying to put on the rotors is pushing the caliper apart, but more so on the bottom. Hope that makes sense.
If it were me, I would buy some inexpensive rotors and good track pads for the track days and swap them on, then take them back off for street driving.
Dan
carguy0119
Apr 11, 2016 11:11 PM
Jazsun
Dec 29, 2014 12:14 PM
bossco
Nov 29, 2014 10:18 AM
