what size shot if any to use
Old Mar 29, 2005 | 12:09 PM
DavesLT1's Avatar
on a forged 396 LT1 stroker with 6" h-beam rods. I'd like to use a small shot like about 75-100, but I worry the rod length might cause the compression ratio under the spray to get too high. anyone know if I could do this?
Old Mar 29, 2005 | 12:37 PM
tufZ's Avatar
Re: what size shot if any to use
A 100-shot will be absorbed with GLEE by that big 396 if you have correct amount of corresponding fuel.
Old Mar 30, 2005 | 12:11 PM
DavesLT1's Avatar
well, I've already picked up the walbro 255 fuel pump and plan to use 42# delphi injectors on a LE3 H/C setup, would a SAFC help control it better?
Old Mar 31, 2005 | 03:51 PM
MeanGreen97Z's Avatar
I'd throw a 150 shot at that bad boy. From other posts you've made the little cam you have in there is not quite big enough but if you put spray on there I GAURANTEE that thing will seriously improve.
Old Mar 31, 2005 | 07:20 PM
DavesLT1's Avatar
right now I believe I have a stock cam, but for the 396 I am going with a full LE3 setup.
Old Apr 1, 2005 | 12:20 AM
94FBIRD's Avatar
Dave, the rod length has NOTHING to do with the compression ratio. However, with a 6" rod in a 396 you're going to have a very short ring stack that will not hold up to a whole lot of nitrous. A 100 shot should be fine, though, in my opinion.
Old Apr 1, 2005 | 01:24 AM
shortdog273's Avatar
Start off with a 100 shot, then work your way up.
Old Apr 1, 2005 | 01:47 AM
Bills77's Avatar
atleast 150 maybe 200, ring pack would be my worry though. but wack it with 150
Old Apr 1, 2005 | 04:49 PM
DavesLT1's Avatar
I was actually thinking about starting with 75 to see how it all works out and moving up, after a good break in. I get a bit nervous with N2O, my last car I only ran a 60 shot while others with stock engines were running 75-100.
Old Apr 1, 2005 | 11:51 PM
94FBIRD's Avatar
Dave, you'll be more than safe with a 100 shot. I'm putting 150 on my stock bottom end car this season. I've read about a whole lot of people in this section running 175-200 on their stock LT1s. With a forged piston in that 396 you'll be fine even with the compressed ring stack.
AND I hope to see you at Bandimere this year. I should be up there on April 22nd. Look for the green Formula.
Old Apr 2, 2005 | 08:30 AM
Make sure you have all of the safety devices: fpss, wot switch, window switch, etc.
RX Speed Works
Aug 20, 2015 03:40 PM
Cam's maro
Aug 11, 2015 07:45 AM
NewsBot
Aug 3, 2015 02:40 PM
Boss002
Jul 24, 2015 10:47 AM
Slayer
Jul 4, 2015 03:06 PM
