Oil pan leak
Old Mar 28, 2005 | 07:42 AM
95 WHITE TRANS's Avatar
Oil pan leak
Hi i noticed an oil leak on the oilpan it seems to be forming right under the screw that let"s the oil out when i do an oil change.It's screwed on thight could it be the washer.
Thanks nick
Old Mar 28, 2005 | 03:06 PM
OBE1 95Z28's Avatar
Re: Oil pan leak
Probably the drain plug gasket; your local part store sells replacement gaskets.
Old Mar 28, 2005 | 06:37 PM
Kataklysm's Avatar
Re: Oil pan leak
Use a paper type gasket instead of a metal washer, it will seal alot better.
Old Mar 28, 2005 | 09:11 PM
1quikZ's Avatar
Re: Oil pan leak
a dab of silicon helps as well
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
