humming sound when driving????
Old Mar 25, 2005 | 10:56 PM
MiNuS-tWo's Avatar
ok well here is my problem. when driving my car it sounds normal and quiet, but when i get up to 60km/h a loud humming sound comes from the front of the car. it get louder the faster i go. the only time the humming sound stops is if i turn a right corner, but then when i straighten out again the sound comes back. what could it be, and i really hope its not too expensive or too hard to fix, or dangerous to drive with. thanks alot. i appreciate everyones help and oppinion with all questions i have asked.
Old Mar 25, 2005 | 11:52 PM
OBE1 95Z28's Avatar
Re: humming sound when driving????
Could be the tire tread; some tires make noise after they wear.
Old Mar 26, 2005 | 09:06 AM
MiNuS-tWo's Avatar
my tires are fairly new, so i dont think that would be the problem. the sound only stops when im making a right turn not a left?????
Old Mar 26, 2005 | 08:47 PM
Dwaynez28's Avatar
On the tire issue, you could swap the tires around and see if the sound moves--little bit of work i know. Dwayne
Old Mar 26, 2005 | 09:07 PM
Bow94z's Avatar
Could be the wheel Hub. the part which is on the steering knuckle and has the studs on them...when the bearing goes bad they humm. just a thought
F'n1996Z28SS
Aug 23, 2023 11:19 PM
kksi
Feb 16, 2015 06:49 PM
karnykamaro
Feb 2, 2015 01:37 PM
squarehead
Nov 21, 2014 08:02 PM
