v6 to v8 swap... long, and part list inside...
Old Mar 25, 2005 | 08:42 PM
Klypto's Avatar
ok, i wrecked my 00z a month ago, i have a 98v6 to do the swap into.(pics in sig of both bars) this list is of almost everything i need to get. and if anything im forgetting, let me know! i live 45 min away from thunder racing, and may get them to do it, or i may do it with a few friends... also.. all my stock parts im replacing, PM if interested in buying them!
Camaro ($13,200) (have, but wrecked in rear)
Engine:
Cam Package: (Sale $539.99)
- Cam (TR224/224-112 .563/.563 112 LSA)
- Comp Cams 26918 Valve Springs
- Thunder Racing Stock Length Pushrods (7.400)
- Titanium Retainers (Sale $134.99)
- Cam Gaskets (Sale $49.49)
Thunder Racing Modified LS6 Oil Pump (Sale $134.95)
JWIS LS1 Timing Chain (Sale $134.99)
Induction:
MTI Clear Lid ($149.00)
SLP LS6 Intake Manifold (Sale $449.95)
Thunder Racing Ported LS1 Throttle Body (Sale $135.00)
LS1 High-Flow Bellows ($49.99)
Drivetrain:
SPEC Clutch Package: ($700)
SPEC Stage III Clutch
SPEC Billet Steel Flywheel
Pro 5.0 Shifter ($180)
Strange HD Driveshaft (~$250)
Strange 12 bolt w/4.10 gears (Sale $2300.00)
- Upgraded Posi
Suspension:
HAL Generation "F" Series Shocks Front/Rear Shock Package: ($742.99)
- Front Springs
- HAL Spring Rates: 275 lb. spring - Drag Racing
Exhaust:
Single 3inch QTP Electric Cutout ($184.99)
Hooker LT Headers ($619.99)
Hooker ORY-pipe ($152.99)
Hooker Cat-back ($339.99)
Misc:
!Cags ($29.99)
!Cats
Appearance:
Xenon Body Kit
Y2k Wheels w/Nitto555 Tires ($1250)
Sub-Total: $6034.81
Tax (8.75%): $528.05
Total: $6562.86
All prices are off the thunder racing website.
some of these i already have ordered.. cant make it colored on this, but i have the colored on the .doc file i wrote.
Old Mar 26, 2005 | 11:46 AM
Mykdiver's Avatar
Re: v6 to v8 swap... long, and part list inside...
Well, I would just port the oil pump myself and put a spacer (About 3-4 washers) in the spring orfice nearest to the plug.
Save $ and don't bother with the smooth bellows, it does not add that much, and unless you are going to be hard core drag racing and need every hundredth of a second in ET it will not matter.
If you want a rear end, I have a hookup with Moser 12 bolts from a friend, and could save you a couple hundred $s.
You will need to use the wiring harness, gauges, PCM, etc from the donor car.
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
The Seer
Nov 20, 2014 06:32 AM
SaxRulez
Jun 12, 2004 09:29 PM
