will factory roller lifters work on Accels High lift cam?
Anyone happen to know if factory style hydraulic roller lifters can be used on accels high lift cams?
im using Accels
74211 211/219 .503/.525 .536/.560 112deg
Im not too sure whether i may have to go with solid roller lifters such as this
http://www.hughesengines.com/www/hug...ler_lifter.jpg
BTW the motor is an 87 TPI
im using Accels
If you plan on using "stock" heads, they won't safely go much more than .420" intake, .450"exhaust w/o machining the valve guides and New valve springs. I'm in the middle of rebuilding mine and I've measured my #083 heads carefully.
oldschool
Feb 9, 2016 09:21 PM
thanx, u sure saved me a world of headaches.
