What exactly is torque management?
Old Oct 13, 2002 | 05:42 PM
Jon 97TA's Avatar
I've been hearing about torque management lately. Anybody have any info on this, or know where I can get some info? I tried a search and couldn't find anything.
Jon
Old Mar 1, 2007 | 08:35 AM
1LESSZ28's Avatar
ttt
Old Mar 1, 2007 | 09:21 AM
2xLS1's Avatar
Torque management is a function of the PCM that reduces engine power
under certain conditions. Torque Management is performed for the
following reasons:
To prevent overstressing the powertrain components.
To prevent damage to the vehicle during certain abusive maneuvers.
To reduce engine speed when the IAC is out of the normal operating
range.
The PCM monitors the following sensors and engine parameters to
calculate engine output torque:
Air/Fuel ratio
Mass Air Flow
Manifold Asolute Pressure
Intake Air Temperature
Spark Advance
Engine Speed
Engine Coolant Temperature
A/C Clutch Status
The PCM monitors the torque converter status, the transmission gear
ratio, and the engine speed in order to determine if torque reduction
is required. The PCM retards the spark as appropriate to reduce
engine torque if torque reduction is required. The PCM also shuts
off the fuel to certain injectors to reduce the engine power in the
case of an abusive manuever.
The following are instances when engine power reduction is likely to
be experienced:
During transmission upshifts and downshifts.
Heavy acceleration from a standing start.
The IAC is out of the normal operating range.
When the driver is performing harsh or abusive manuevers such as
shifting into gear at high throttle angles or shifting the
transmission from reverse to drive to create a rocking motion.
The driver is unlikely to notice the torque management actions in the
first two instances. The engine power output will be moderate at
full throttle in the other two cases.
The PCM calculates the amount of spark retard necessary to reduce
engine power by the desired amount. The PCM disables the fuel
injectors for cylinders 1, 4, 6, and 7 in the case of an abusive
manuever.
Old Mar 1, 2007 | 10:09 AM
01Z's Avatar
01Z
This ^ answer is a real keeper....
Old Mar 1, 2007 | 10:14 AM
orange terror's Avatar
I thought it was directly related to how hard you pressed your right foot, lol.
Old Mar 1, 2007 | 10:25 AM
2xLS1's Avatar
It's GMs description of TM from their literature.
Old Mar 1, 2007 | 10:53 AM
01Z's Avatar
01Z
I figured as much but you have the resource. Please keep posting this kind of information if you have it. Sorting through fact and fiction is an art. When someone posts authentic stuff it stands out. Thanks!
Old Mar 1, 2007 | 11:14 AM
1LESSZ28's Avatar
I second that! best answer I have ever seen on the subject
93 RedBird
Nov 15, 2015 08:24 AM
drt
Sep 27, 2015 04:39 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
