what's involved 94z moser 12 bolt setup?
Old Mar 13, 2005 | 06:42 PM
heliskiier1's Avatar
Question what's involved 94z moser 12 bolt setup?
Looking at one now. Any mods that need to be made to put this puppy in? Is it a job I can handle in the garage with a turnkey setup? Thanks!
mudkat
Old Mar 15, 2005 | 09:30 AM
Re: what's involved 94z moser 12 bolt setup?
little help? how much should I pay for a full used setup?
Old Mar 15, 2005 | 01:41 PM
roguedriver's Avatar
You will probably need a shorter driveshaft, although i've heard of some using their stock lengths. I tried to get my stock length in there and it's too long. Check with Denny's driveshafts on the net and he'll set you up. Not much to it. No other mods needed really assuming you get the right size sway bar hardware with the rear end cause the axle tubes are bigger then the stock tubes. You can do it in the garage but 2 people is always nicer.
Ken R.
Old Mar 16, 2005 | 09:18 PM
EDS Z28's Avatar
I did it myself. No sweat.
To change out the motor your going to need another guy for sure!
HarleyZ28
Oct 5, 2015 06:23 AM
ddr698
Jan 9, 2015 10:05 AM
rje
Sep 9, 2002 12:35 PM
kev93z28
Aug 19, 2002 12:48 AM
