Aftercooler and HP?
Old Mar 11, 2005 | 03:59 PM
BlownF1's Avatar
Aftercooler and HP?
Those running vortech's Aftercooler...how much HP are you making?
Old Mar 12, 2005 | 01:55 AM
ss#1230's Avatar
Re: Aftercooler and HP?
a little over 400rwhp.... running rich at 10.2:1 before tuned. not dynoed
since.
6psi kit with stock bottom end.
answer me this...how do you pass smog here?????
Old Mar 12, 2005 | 09:19 AM
engineermike's Avatar
I've made 550 through an auto/loose converter through it. Others have made 620+ with it.
I'm betting I'm in the 650 range with 18 psi from a turbo now.
Mike
Old Mar 12, 2005 | 09:29 AM
LWM's Avatar
LWM
Best session on the dyno was 559 rwhp.
Needed a dash of Xylene ...
LWM
Old Mar 13, 2005 | 05:32 PM
ss#1230's Avatar
Blown F1....seriously...how do you get passed smog?????
Old Mar 14, 2005 | 08:26 AM
BlownF1's Avatar
Thanks guys. Vortech lists it as good for 450hp...
SS#1230...what do you mean? Short of the cam swap, everything is smog legal and the car blows beautiful numbers on the test.
Old Mar 14, 2005 | 09:09 AM
Vortech396's Avatar
I made 650 at the wheels with a T-trim/Aftercooler and pump gas. On the engine dyno it made 925 with 100 octane at 14 psi.
later
John
Old Mar 15, 2005 | 06:04 PM
ss#1230's Avatar
does your cam have much lope to it? i havent smogged yet with my hotcam but it makes a pretty noticable lope with my tiny flowmaster. it passes the sniffer for sure but im just worried about raised eyebrows when they listen to it....
BTW, who did your motor?
jeremy
Old Mar 15, 2005 | 10:41 PM
BlownF1's Avatar
Yes, but the supercharger is CARB approved and "puts a heck of a load on the engine at idle".
A friend of my brothers in CO...called ELPES Racing. He builds lots of roundy-round car motors, but is not an LT1 specialist by any means though. Can't really complain too much though, it seems to be running pretty good...goes back to the dyno again this Saturday with a new tranny this time.
Old Mar 16, 2005 | 12:42 AM
ss#1230's Avatar
looks good. how much did id cost you to have the motor work done? did you take the whole car to him?
Old Mar 16, 2005 | 08:11 AM
BlownF1's Avatar
He did the longblock (roughly $5000 I'd guess, it's been awhile) using my heads, but we ended up swapping the cam and Advanced Induction supplied new AFR heads...I'd of been better off with a shortblock. Myself and 2 buddies did all the work. I got wise and quit taking my car to "professionals" long ago...
Old Mar 16, 2005 | 10:57 AM
EDS Z28's Avatar
I've got long tubes and can pass. The flp's have the air & egr hookups. IT just adds an extra converter which helps the flow a lot, but is technically not carb legal. It smogged very clean with this exhaust on the car. Stock tuning except for the injector constant is set to 42, that's it.
As far as the aftercooler, I haven't dynoed it yet since installing the vortech kit on my car, but I can testify that the motor makes more torque than it ever has and the blower is nice and quiet. I previously had the ati p600b 12-rib setup with twin intercoolers, which made over 500 rwhp.
Old Mar 16, 2005 | 06:34 PM
RCF925's Avatar
I have flunked smog pre-test twice in CA. 1st time I failed 4 out of 4 tests, 2nd time last week I passed 3 out of 4 but am still running rich at 2500 rpm. I cleaned up the idle through programing and I just put on a EGR solenoid that I think was bad and will try again next week. My biggest problem is the 72# injectors running rich at idle which I have solved, Hopefully I'll get it to pass next week. As far as power I haven't finished tuning and am running a smog tune til it passes but with 5psi boost I'm at 540rwhp, I'm shooting for 600 rwhp at this boost level
Old Mar 16, 2005 | 09:42 PM
ss#1230's Avatar
HEY ED, are you running the v2 SQ or just the regular s trim?
RCF925, what happens when you fail? how long do you have to correct the problems and do you get charged any kind of fines?
Old Mar 16, 2005 | 10:12 PM
I like Louisiana.
