Brake problem...help!
Old Mar 11, 2005 | 03:02 PM
94Z28rag's Avatar
Exclamation Brake problem...help!
I'm posting this for a friend who has a 1997 Z28.
Ok, here's the situation:
When driving and coming to a complete stop i must push in the brake ALL the way, keep in mind the peddle is SOFT and not HARD. This happened all of the sudden and now i get the "brake" indicator on the dash. I checked the fluid and all is fine. My e-brake wasn't engaged for the light i checked that. It just when stopping i have to push the SOFT pedel all the way in for a complete stop. What do you think is wrong? Is it the master cylinder? Vaccum booster? Fluid is fine and i changed the pads not that long ago.
TIA
Old Mar 11, 2005 | 11:15 PM
Bone Daddy's Avatar
Re: Brake problem...help!
Tell your "friend" that he probably has a master cylinder going bad if the ABS light is coming on. This is assuming your "friend" has checked the master cylinder, the ABS pump, and all 4 corners for leaks; and everything looks normal.
Old Mar 11, 2005 | 11:57 PM
94Z28rag's Avatar
Thanks for the reply, I will tell HIM that.
My brakes work just fine, thanks.
Old Mar 12, 2005 | 12:09 AM
Bone Daddy's Avatar
TIA
Suuuure they do.
Old Mar 12, 2005 | 11:38 AM
94Z28rag's Avatar
He is "97Z28kid" on fbody.com. He does not have an account here, so I told him to write up a post and email it to me and I would post it here for him.
Why would I have a hard time admitting i have a problem with the car? God knows i post about a lot less-involved problems with my own Z...
But, when i do have a problem with my car, with exception to the transmission ones I have already, I'll make sure to let everyone here know.
Old Mar 12, 2005 | 12:33 PM
Bone Daddy's Avatar
Jesus, if you're careful enough.. and you believe in love, you just might remove the stick from your ****.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
