Speed Speciality
Old Mar 7, 2005 | 03:59 AM
GoFast908Z's Avatar
Member
Speed Speciality
I noticed they sell some cross drilled and slotted rotors for LS1 F-bodies. Has anyone tested these rotors out? I need new brakes and they are a bargain price!
Old Mar 7, 2005 | 06:28 AM
teke184's Avatar
Re: Speed Speciality
bargin compared to what? $100+ per rotor isn't much of a bargin to me.
drilled and slotted alone will probably not give much of a difference in braking ability. possibly less fade due to keeping cooler after repeated use. but it's more the type of pad you use that hlps breaking.
check out the "susp and brakes" forum for more on them and other brakes
Old Mar 7, 2005 | 11:33 AM
GoFast908Z's Avatar
Member
its $50 per rotor. Its basically the same price as OEM-style replacements cost. Thats why I'm interested, but it does seem a little too low to be quality.
Old Mar 7, 2005 | 01:29 PM
teke184's Avatar
sounds to me like they are just drilled/slotted OEM rotors, which means they are more liable to crack and warp since they were not designed to have holes/slots on them.
i would pass
stick with some good pads and you should be fine with stock rotors
Old Mar 7, 2005 | 03:46 PM
GoFast908Z's Avatar
Member
They are not stock rotors. Take a look.
http://www.speedspecialty.com/store/...product=rotors
Remember I'm looking for replacement rotors and I stumbled upon these. So any upgrade for around the same price is just a bonus. And I already have good pads.
Old Mar 7, 2005 | 04:09 PM
n2oblkz
Guest
Posts: n/a
They look like they are a pretty good rotor. I may be wrong, but I think that they are a sponsor on LS1Tech.com. I remember seeing a speacial on rotors and I could have sworn it was them. You may want to do a search over there and see what you come up with.
Old Mar 8, 2005 | 06:53 AM
teke184's Avatar
are you SURE they are not just machined stock units? i mean they give you the choice of slots, dimples, drilled etc...as well as color...
makes me think they are doing the machine work themselves.
i mean...PowerSlot rotors are about $100 each...and many consider those somewhat lower quality rotors.
so it makes me think drilled/slotted rotors for $50 each is even more of a step down.
see my point?
from a picture how can you tell for certain they are not dolled up OEM units? unless you wanna take an advertiser's word for it
Old Mar 8, 2005 | 12:58 PM
GoFast908Z's Avatar
Member
The rotor hat doesn't look the same size as OEM. But I'll call them and ask about it. Has anyone here actually tried them though?
Louey
Pacific
Apr 7, 2015 02:10 AM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
