Best Quiet Exhaust
Old Mar 3, 2005 | 04:14 PM
MiNuS-tWo's Avatar
Best Quiet Exhaust
right now i have a 95 3.4l camaro with a flowmaster exhaust on it. ive gone through a few different setups. with stock cat in place, with straight pipe in place, with a larger cat in place. but none of the setups i have really liked. ( just need to get a Z28 ) anyways im going to be getting a new exhaust very soon, but was wondering which aftermarket exhaust i could get that would return it to stock (Quiet) sound? i want to keep the same look that i have now, with the dual chrome tips. any suggestions would be great thanks.
Old Mar 3, 2005 | 04:24 PM
codyss's Avatar
Re: Best Quiet Exhaust
If you want awesome flow but need it quiet go with a SLP/Magnaflow/UltraFlo/Borla style Muffler. Or you could also run a Dynomax Super Turbo which will out flow Stock and the Flowmaster and the sound level will be between the others I listed and stock.
A complete Dynomax Cat-Back is verycheap and you could always cut there tips and use your own.
Old Mar 3, 2005 | 04:27 PM
km9v's Avatar
I run a Dynamax. It's fairly quite on idle & highway, decently load under acceleration.
Old Mar 3, 2005 | 06:07 PM
snake_skinner93's Avatar
ever heard of Raven exhaust mufflers? they're Flowmasters rival i guess you could say, they're a lot quiter, but gives you a decent sound with some throttle. i think the muffle alone is only like $90 or so. might wanna check into them.
Old Mar 3, 2005 | 06:24 PM
MiNuS-tWo's Avatar
Thanks for the input so far. Ive been thinking about the magnaflow ( that is what the parts people here recomend ) and its reasonable priced, i hope. (approx. $180 )
Do you have a webpage for the Raven Exhausts. i would like to look into them a little more but cant seem to find any info.
Any more suggestions would be great, i have a couple of weeks to search for the best exhaust for the best price, before i commit to one.
Thanks again
Old Mar 3, 2005 | 07:26 PM
codyss's Avatar
If you want good flow stay away from Raven/Flowmaster/Pypes ProV/Spintech
Old Mar 4, 2005 | 11:17 AM
Joe 97RA's Avatar
Borla makes a rear section that is perfect for a V6. It is not the adjustable cat back, it is merely the muffler and tailpipes. Better flow, better sound and stainless construction.
Old Mar 4, 2005 | 11:28 AM
moparman's Avatar
Get a Hooker.
Old Mar 4, 2005 | 12:17 PM
zhevy-1's Avatar
If you want quiet stock like sound exhaust, put the stock one back on.
Not to sound like an ***, but most aftermarket exhaust are designed for performance, and with that, it comes the sound.
Old Mar 4, 2005 | 12:33 PM
MiNuS-tWo's Avatar
i dont think you are sounding like an ***. i would put a stock exhaust back on but i still want the look of the dual tips out the back. i dont really mind a little louder than stock sound, but i definetly dont want the sound of the flowmaster that i have ( personally its almost embrassing to drive around with it on ) it sounds like *** (just my oppinion).
Old Mar 4, 2005 | 11:26 PM
2000LS1Z28's Avatar
It sounds like "A$$" because you have a 3.4L V6 under the hood. I'll agree Flowmaster doesn't sound the best on V6's, but IMO, nothing will ever sound good as compared to anything on a V8. I had a 3.8L Camaro several years ago with a Borla cat-back, stock cat, & RKSport headers and it sounded descent at idle and low revs, but was "embarassing" like you described from the mid rpms up. It's a losing battle with sound when you have less than eight cylinders under the hood. Since you really want the look of two tailpipes, I'd highly recommend a stock Z28 or SS muffler w/ tips as it doesn't sound annoying or bad like all the aftermarket systems would on your six-banger...Just a little louder than the stock muffler, but with a little better flow and the look you want.
Should do until you get a Z28. Trust me, I bet you'd love that same Flowmaster on a V8 though.
Good luck,
Mike
Old Mar 5, 2005 | 11:43 AM
best thing to do is find you a Z28 or Trans-Am stock muffler and get whatever tips you want and slap it on your car. my fiance had a Flowmaster on her '93 3.4 and she just got tired of the sound after a while and wnated factory quiet again. she and i swapped mufflers...my Trans-Am stock muffler for her Flowmaster and she put Z28 tips on the stocker...looks good and gives it a little sound too...but nothing at all loud.
EDIT - sorry, the post above me already says the same thing i did. i didnt read until after i'd already posted.
Old Mar 6, 2005 | 12:23 AM
2000LS1Z28's Avatar
Originally Posted by robvas
The 3.4 sounds way, way better than the 3800 does
Better sounding or not, neither sounds very good above 2000rpms with an aftermarket muffler/cat-back...
Like I said, a stock LT1/LS1 muffler w/ tips (you could even use the stock 2.75" I-pipe too) would work great for what you want...It would be a descent sound/tone with dual outlets...Your 3.4 actually wouldn't sound too bad when getting into the throttle some this way...Flow would also be improved too...
Old Mar 7, 2005 | 12:34 AM
MiNuS-tWo's Avatar
does anyone have a sound clip of a stock Z28 muffler on a 3.4l or 3.8l ???
kxrawx
May 25, 2015 08:29 PM
May 21, 2015 01:04 PM
May 15, 2015 10:43 AM
Apr 16, 2015 09:57 AM
karnykamaro
Feb 2, 2015 01:37 PM
