rear axle oil? what brand you use
Old Feb 26, 2005 | 01:56 PM
iCE's Avatar
iCE
Arrow rear axle oil? what brand you use
it is time for the rear axle oil change. its making a clunking noise on sharp turns. Just curious as to what kind of rear axle oil everyone uses. I have heard Torco is good stuff.
and for the procedure all you need besides tools:
*new gasket
*new oil
*gm additive
right?
Old Feb 26, 2005 | 02:20 PM
neil350's Avatar
Re: rear axle oil? what brand you use
I'm tempted to let the mobile 1 place by my house do it on my TA, they charge 33$ with the additive.
Old Feb 26, 2005 | 02:36 PM
pearlpurple's Avatar
your right for the GM additive as I found out
Thought I would change the rear gear oil got some synthetic Mobil 1, and some "limited slip" additive from Autozone. Did the change and at the same time I did my back brakes.
Soon after the car wold "jerk" around sharper corners at low speeds say at a stop sign or turning into my street. After checking the brakes and rear I narrowed down to the rear end thought it might be on the way out so I took it to a GM dealer they serviced with all GM oils and additive and has been smooth ever since.
Old Feb 26, 2005 | 03:25 PM
Kain's Avatar
I just used whatever was at Autozone, but don't forget the GM limited slip additive. Get it at your local GM dealer.
Old Feb 26, 2005 | 06:07 PM
1quikZ's Avatar
Royal Purple Synthetic with of course the GM additive
Old Feb 26, 2005 | 09:07 PM
iCE's Avatar
iCE
would this stuff work good?
Old Feb 26, 2005 | 10:31 PM
gmr speed's Avatar
I always use GM fluid and the addive slip. Never had any issues. I used other stuff and didnt like it.
Old Feb 27, 2005 | 10:08 PM
92RS305#2's Avatar
i used lucas oil heavy duty 80-90W with the additive aurburn sent me, i woulda used syn but auburn recommended non-syn. i also accidentally bought some gm additive or 7 bucks. just remember for every quart of gear lube you need 3oz of limited slip additive.
Old Mar 1, 2005 | 01:54 AM
canuck94z28's Avatar
Smile Re: rear axle oil? what brand you use
i used pennzoill 80w90 hd plus; it has the additive already in it.
Old Mar 1, 2005 | 07:03 PM
Bawls's Avatar
I used mobile 1 75w-90 w/o additive. No problems.
Old Mar 2, 2005 | 01:00 AM
Spinner's Avatar
Cheap generic 75w90 and the GM additive. Works fine.
Old Mar 2, 2005 | 02:37 AM
Red5.7's Avatar
Wolfs Head 80W-90
Old Mar 2, 2005 | 10:14 AM
Roadie's Avatar
Additive? I don't need no stinking additive...
...in my 9"/detroit locker combo
Old Mar 3, 2005 | 02:37 AM
Pro Built Automatics's Avatar
LE is the best, but expensive. Lucas is the next in line. Torco was "once" a very good oil, but they changed their formula........ and always add the GM posi additive.
Old Mar 3, 2005 | 02:32 PM
BadCo.'s Avatar
I used some Castrol non synthetic gear oil of the correct viscosity , I put this same stuff in the final drive on my bike. Just plain ole Castrol and the Gm additive of course.
edit: works fine, great, no problems
