Driveshaft Question
Old Feb 24, 2005 | 07:11 AM
transamdude95's Avatar
Driveshaft Question
Would a driveshaft from a 2001 T/A with the 1350 u-joint and stock yoke fit on my 1995 T/A?
Old Feb 24, 2005 | 08:24 AM
CreatiVe2's Avatar
Re: Driveshaft Question
i have a 2000 trans am aluminum driveshaft in my car now... as long as you have a seriers 3 carrier (stock gears for a4 i THINK are 3.23) so you should be fine
but the U-joint should come already mated on the Driveshaft...
Old Feb 24, 2005 | 08:57 AM
teke184's Avatar
i'm not familiar with the ujoints....is the 1350 stock?
cause all driveshafts from 83-02 are interchangable...v8, v6, alum, steel, 3rd gen, LT1, LS1...all of them.
Old Feb 24, 2005 | 09:23 AM
97FormulaWS-6's Avatar
1350 joint will not fit a stock car, the 1350 joint is what is used for a 9" or 12-bolt.
You need a standard 1320 joint for the stock 10-bolt rear axle.
Otherwise the DS should work just fine.
Old Feb 24, 2005 | 11:11 AM
Thanks for the info! I appreciate it!
Old Feb 24, 2005 | 11:50 AM
94formulabz's Avatar
I'm not trying to nitpick, but some 9" and 12 bolts use 1330 yokes, most the 1350 though.
Stock yoke is a saginaw 3R, I've never heard it called a 1320, but maybe that is a synonym. 1LE uses 1310 with a conversion ujoint at the rear to mate up with the 10 bolt 3R.
-brent
Old Feb 24, 2005 | 02:52 PM
*Shrugs* I wouldn't doubt that you're right, I don't know everything...
Just know the ones I've delt with have all been 1350 U-joints... but then again, all of them have been aftermarket yokes, so that may have something to do with it too.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
