lt1/ls1 suspension questions
Old Feb 19, 2005 | 11:19 AM
DisturbedZ28's Avatar
I decided to get another camaro,an ls1.I already have a fully built/stroked lt1 car and i plan on spraying it for a season or 2 and then once the motor's had enough,i want to put my suspension parts in the ls1 car.Will everything swap over from the rear suspension(i know the fronts are different)...but will my torque arm(spohn adj) lca's,panhard bar, rear sway bar ,etc fit the ls1(it should right??). I'm also goin to want to swap my 12 bolt into the ls1 but i know the ls1 cars have a 4 channel abs w/ tcs can i modify my existing 12 bolt for this or will i have to sell it and get one specific to an ls1 car??...thanks for any help you guys can give me
Old Feb 19, 2005 | 11:41 AM
Flyin_Z28's Avatar
Re: lt1/ls1 suspension questions
I know the rear is exactly the same or darn close. I have SLP suspension from an LS1 in my car. Works great. Don't know about the 12bolt. Might want to ask about that in Drivetrain section.
Old Feb 19, 2005 | 06:14 PM
mongse_1's Avatar
Rear suspension should sway right over.
As for the 12-bolt, the 4-channel setups put the ABS pickup out by the rotors, while 3-channel (non TCS cars) had it inside the center section on a reluctor ring. Switching it over can be done, but it'd be a chore, unless your LT1 car came w/ TCS.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Hurin
Dec 13, 2014 07:38 PM
