What's involved to swap in a 95+ 4L60E into a 94 F-Body?
Old Feb 16, 2005 | 08:37 AM
My94RedZ28A4's Avatar
I know the 95+ use OBD-I computers, with the OBD-II connector. I also know that the 95+ 4L60E Trannies use PWM for the TCC, whereas the 94's don't. Because trying to find a replacement tranny for my 94 is a PITA, What's involved in getting a 95+ to work? Can I reflash my ECM with code from a 95+ vehicle, or are there wiring changes and/or mechanical (bellhousing, case length, different splines, etc...) changes...
Thanks in advance
Old Feb 16, 2005 | 12:31 PM
94Zpower's Avatar
Re: What's involved to swap in a 95+ 4L60E into a 94 F-Body?
I think that the 94 has a single plug harness and the 95 is a double plug and if I am not mistaken it has something to do with the lock up on the Converter,
I could be wong so check it out.
hope this help at leat point you in the right direction.
Old Feb 16, 2005 | 11:23 PM
redimpss5's Avatar
I had a 96 4l60e in my 94. Works fine. You need to change the harness in the tranny pan and it will work great.
Old Feb 16, 2005 | 11:42 PM
What do you mean by change the harness? In other words take off the 95+ harness and plug your 94 harness in?
Do you have any pics or anything? Thanks in advance!
Old Feb 16, 2005 | 11:48 PM
madwolf's Avatar
You will need reprogramming for a 95 tranny and run a wire from the pcm to the tranny connector. It's the PWM wire. Check shoebox's website for diagrams.
HectorM52
Jul 30, 2017 11:46 AM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
Jmlcolorado
Jul 4, 2015 08:31 AM
cmdeshon
Dec 12, 2014 10:51 PM
