3.73 M6 guy's, what are you shift points?
Old Feb 12, 2005 | 10:57 AM
speed_demon24's Avatar
Mine seem kind of low to me. These are at 6K and I'm wondering if they are normal.
1st gear (spinnin like a ****)
2nd 60-65 (spinnin)
3rd 85
4th 115
And at 80mph I'm at 2150 RPM's. I looked it up on F-body.org/gears and mine are off from what that says. And I'm sure my PCM is calibrated for 3.73's. Are these the normal shift points?
Old Feb 14, 2005 | 11:25 AM
bubba353z's Avatar
Re: 3.73 M6 guy's, what are you shift points?
They do seem a little low, from my calculations. What is the diameter of the tires you are running? That could be the difference.
Old Feb 14, 2005 | 12:41 PM
stock size 245/50/16's. And the clutch definatly isn't slipping, I get more than a chirp going into 3rd...
Old Feb 14, 2005 | 12:54 PM
4SFEDZ's Avatar
I changed my shift points and i dropped like 1 tenth.
1st 5400
2nd 5700
Old Feb 14, 2005 | 12:56 PM
4SFEDZ's Avatar
It helped me get a little more traction and on 3rd gear (6000). I accidentally pressed enter so i put 2 separate posts.
Old Feb 14, 2005 | 01:18 PM
What I mean is what MPH are you guys at when you are at 6K in each gear.
Old Feb 15, 2005 | 11:18 AM
bubba353z's Avatar
Using a 25.5" tall tire, I came up with the following speeds @ 6k:
1st - 46
2nd - 69
3rd - 94
4th - 122
5th - 165
6th - 244 (if you could overcome the drag and the jump to .5 o/d)
A shorter tire will lower these numbers, but I think your tires are pretty close.
You may also want to check the accuracy of the speedo against the mile markers on the freeway, to see if it's off. Even though you may have recalibrated the ECM, it could be off a bit.
Old Feb 15, 2005 | 12:36 PM
I think alot of it might be speedo lag. I ran it up to 6K in 3rd and pushed in the clutch and the speedo kept pulling and stopped at 91. And i heard the stock tachs might be off by a couple hundred rpms....
Old Feb 15, 2005 | 06:10 PM
bubba353z's Avatar
My tach is about 200 rpms off - forget which way though
Old Feb 15, 2005 | 07:05 PM
Ken S's Avatar
That sounds about right, what I about see with my 3.73's.
And makes jives with what I used to see with 3.42's. (numbers being about 9% higher (since 3.42's are about 9% longer than 3.73's)
1st - 46
2nd - 69
3rd - 94
4th - 122
5th - 165
blac94Z
Jan 12, 2015 05:44 PM
cmdeshon
Dec 27, 2014 10:06 AM
Red97LT1
Aug 7, 2002 05:45 PM
