help with the turbo XS type 25 bypass valve..
Old Feb 10, 2005 | 06:58 PM
CoUnTryMuZiCZ28's Avatar
Im trying to adjust it to make sure it stays closed at WOT. If I add the washers to it, it doesnt open at idle.. But if I leave the washers out it seems to work fine but I think its leaking at WOT.. Is there anyway to tell??
Old Feb 11, 2005 | 05:20 PM
SMOKNZ's Avatar
Re: help with the turbo XS type 25 bypass valve..
Well your either going to have to run REAL fast, or check it on a dyno at WOT.
Another way would be to check the valve with a mityVac that does pressure or a regulator off an air compressor. Put 7 psi or whatever your running on the valve and check if it's shut.
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
Hal Fisher
Sep 30, 2015 09:03 PM
CARiD
Sep 30, 2015 05:44 AM
surreybrad
Sep 29, 2015 09:00 PM
