1989 Notchback coupe 1500 mile 306 CI,tremac,etc in NJ (NEW PICS!) ONLY $3550
Ok fellas this post is for my 1989 Ford Mustang LX notchback. The motor blueprinted and balanced by a local machineshop. No corners cut! The motor has JE forged pistons and rods,stock cut and balanced crank,heads pressure washed and is bored .30 over making it 306 ci, It has only 1400 miles since i picked it up over a month and a half ago. Here is a list of mods and info on the vehicle
Forged Pistons
Melling oil pump (<---spelling?)
Motorsport E-303 cam
BBK headers
Mass air meter (73)
Felpro gasket set
new starter
351 windsor heads
new ford motorsport timing chain
ARP bolts
ASP crank pulley
new downs ford tune up kit (8mm wires cap rotor etc)
Walboro 255lph fuel pump
Cobra Clutch kit new
MSD Blaster coil
New distributor
K&N fenderwell cold air
Subframe connectors
new resurfaced flywheel
SN95 Front seats w/electric drivers
Pony wheels
Tremac 3550 5-speed
pro 5.0 shifter
Flowmaster mufflers
Kenwood CD player
160 speedo
6 piece clear headlamp kit
3:73 gears
MORE PICS
http://community.webshots.com/user/cjd5057
IT NEEDS OR COULD USE
A 8.8 rear,the car has a 7.5 rear with 373's in it and runs and drives great and was just filled with fluid when the motor was finished. I just wouldn't reccomend keeping the 7.5 if you plan to run the car at the track.
Also not necessary but could use some new paint.The car actually looks ok but the previous owner took it to macco and got a cheap paint job where they didnt paint the door jambs or under the hood. It doesnt look bad its just not my taste. You can judge for yourself by looking at the pics
Also sometimes 4th gear will make a small grind doesnt pop out or anything must of the time it doesnt even make the grinding noise.
The cold air induction coming from the tb has the stock rubber on it
I had to put the stock intake and valve covers on it because the parts were on back order and still havent arrived here.
This car has been my daily driver since i picked it and has no mechanical problems at all. Runs and starts everytime doesnt stall and passed NJ emmisions with ease.Since the new speedo was put in it says the car has 120k miles on body. Only 1500 miles on the new forged motor. Im looking to get 3550 or trade for 94 + Z28 or Trans Am A4 or M6 but must have T-tops. Please dont send a private message but E-mail me directly
E-MAIL CJ306lx@yahoo.com
Forged Pistons
BBK headers
Mass air meter (73)
Felpro gasket set
new starter
351 windsor heads
ARP bolts
ASP crank pulley
MSD Blaster coil
New distributor
Subframe connectors
Pony wheels
Tremac 3550 5-speed
pro 5.0 shifter
Flowmaster mufflers
Kenwood CD player
160 speedo
3:73 gears
MORE PICS
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Henson071
May 4, 2015 12:23 PM
