Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Engine Makes Howling Noise!!!!!!!!
Old Feb 9, 2005 | 04:06 PM
IKILDVPRKILLER's Avatar
The other day I went to the gas station and filled up with gas and noticed when I started the car the was a low toned howl. When I hit the gas it went away, but now whenever I hit the gas you can hear the howling coming from the intake manifold when you hit approx. 2500 rpms. I doesn't do it any where else. It doesn't matter if the car is in neutral or if you have the clutch pressed. However it doesn't do it when your driving. Power is still there and oil pressure is still there. I have checked my belt already. Please help.
Old Feb 9, 2005 | 05:17 PM
IrocSS85's Avatar
Re: Engine Makes Howling Noise!!!!!!!!
what about the pulleys? or the accessories? take off both belts and start it up and see if the noise goes away. that'll eliminate all that as possibilities. good luck
chris
jcamaro95lt1
Jan 24, 2015 08:21 AM
ro2207
Dec 4, 2014 06:18 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Omega9
Aug 2, 2002 12:33 AM
