Wet Kit minus Fuel
Old Feb 9, 2005 | 03:16 AM
13sectransam's Avatar
Wet Kit minus Fuel
This is for a different car, but i have a nitrous question thats kind of general. If I run a wet kit on a supercharged car, I've heard its bad to spray before the blower because it will compress the fuel and blow the SC right off. But if I were to run the kit without the fuel side connected, would it act as a dry kit? And if it did, would it supply its own extra fuel? Or would I need an adjustable regulator. Thanks.
Old Feb 11, 2005 | 03:03 AM
ChevyTuffD.A.'s Avatar
Re: Wet Kit minus Fuel
I wouldnt think spraying fuel through a blower would be a good idea. You could use it as a dry kit as long as u sprayed it through your maf sensor and as long as your fuel injectors will support it.
alphaauto
Jan 23, 2015 07:42 AM
JamesN1830
Sep 11, 2002 10:57 AM
rje
Sep 9, 2002 12:35 PM
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
