Why did the STS-v & XLR-v engines go to 4.4L??
Old Feb 8, 2005 | 11:06 AM
Z28x's Avatar
Why did Cadillac go with S/C 4.4L instead of S/c 4.6L for the newest V-series car?
I know GM has been playing with the 4.4L Northstar for a little while (Bonnie GXP concept) 4.2L S/C northstars were also used in the Evoke and Imaj concepts.
So what does the 4.4 have that the 4.6 doesn't?
Old Feb 8, 2005 | 11:07 AM
Big Als Z's Avatar
Re: Why did the STS-v & XLR-v engines go to 4.4L??
4.4 has thicker walls to handle the power.
Old Feb 8, 2005 | 11:45 AM
0toinsanein5.4sec's Avatar
could have found they got better reliability out of the 4.4 with an SC and that they could bppst up the psi
Old Feb 8, 2005 | 12:51 PM
MissedShift's Avatar
Bingo. GM said that they wanted the thicker cylinder walls to deal with the increased cylinder pressure.
Old Feb 8, 2005 | 04:17 PM
redzed's Avatar
The Northstar V8 has tighter bore spacing than the Chevy smallblock - or even Infiniti's VK-series V8. The bore spacing issue is why the Northstar V8 hasn't grown in displacement, and it's also why the S/C was de-bored for the sake of durability.
Why does the STS-v have 4.4 liters instead of the 4.2 like the Evoq and Imaj? The 4.2 liter had the same bore as the then-current 3.5 liter "Shortstar" V6. GM had planned on continuing the "Shortstar," and the Northstar based V6 was planned for the Cadillac CTS and the other Sigmas. When the Shortstar was cancelled (for some very good reasons) there was not point in maintaining the smaller bore size, so we've got a 4.4 liter S/C Northstar.
The ironic part is that the Northstar is on its way out and the replacement will probably share its block architecture with the Chevrolet small-block V8.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
