Whats wrong with tranny?
Old Feb 7, 2005 | 09:13 PM
dabez1's Avatar
I have a 94 A4 t/a and out of no where when i put the car on D it would make somekind of grind/crack noise, It wont do this when i put it in reverse. It also does the noise when it shift into 2nd gear while going at high rpm.
Old Feb 8, 2005 | 03:27 PM
BoobSter-lt1-z's Avatar
Re: Whats wrong with tranny?
Is there a light Thumbing or hammering underneath the car right where your shifter is cuz if there is it might be your tranny mount
Old Feb 8, 2005 | 06:29 PM
94Zpower's Avatar
I 2nd that one it does sound like the trans mount
Old Feb 8, 2005 | 09:05 PM
dabez1's Avatar
I recently replaced the tranny mount, but im hoping it is again. This time thought it maked more of a grindind/slap noise, instead of a bump to the bottom of the car.
Old Feb 9, 2005 | 08:47 AM
I went through 3 tranny mounts in a 2month period from AUTOZONE and I finally went to PAW and purchased a Polysomethingsomething (its a rubbery one) and never purchased a tranny mount since and this was about 3 yrs ago.
By the way, the last tranny mount that I replaced was cracking and it still made a light thumping. You might want to check out first.
Old Feb 9, 2005 | 08:06 PM
92RS305#2's Avatar
polyurathane...
and it could be a tranny mount but a bad bearing can also cause a grinding noise but i'm not so sure its that. grinding noises are usually more common in manuals than autos...
Mikes 1994 z28
Oct 10, 2015 07:55 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
