Dicussion: Velocity of Purge
Old Feb 2, 2005 | 11:32 AM
"White Knight"'s Avatar
I want to start this thread about the velocity of a purge. And how to manipulate it....
I'm trying to think if this can be calculated. But wouldn't you need to know the volume being flowed?? besides the psi and diameter of the lines
something to ponder.......
Old Feb 2, 2005 | 01:10 PM
NXRicky's Avatar
Re: Dicussion: Velocity of Purge
our purge will use 1.2 lbs of nitrous ever 10 seconds.
Not sure if that is the information you want?
Ricky
Old Feb 2, 2005 | 04:11 PM
xfreshjiv12x's Avatar
Need to know the Dia. of the tubing being used.
Old Feb 2, 2005 | 05:23 PM
NXRicky's Avatar
3/16 stainless hard line.
Ricky
Old Feb 2, 2005 | 11:31 PM
now we're getting somewhere....
It's like 1:00a.m. right now so i can't think but maybe tommarow i'll start putting some info together and see what numbers i can get. I am curious as too how high it is, when it exits the line.
Old Feb 2, 2005 | 11:32 PM
Hey NXRickey do you work for NX??
Old Feb 3, 2005 | 10:21 AM
NXRicky's Avatar
Yes I do. I am the General Manager for NX.
Ricky
Old Feb 3, 2005 | 10:58 AM
mongse_1's Avatar
and all this time I thought you worked for Vortech!
What is your recommendation on how far apart the purge solenoid should be from the nitrous solenoid? I always tried to keep my purge as close as possible to the nitrous solenoid (connected if possible like w/ the Iceman solenoids).
Old Feb 3, 2005 | 04:22 PM
Ricky
Just the guy i have been needing to talk to. I have a question on particular parts. Can you get NX fuel rails and NX nitrous rails individually (the ones in the 90006 kit)? and how much do they run? Also can you buy the just the MAF end/nozzle by it's self--like if you have everything else and just want to convert to the MAF set-up. Because i have a friend that wants to do this, and he has just the basic set-up right now.
Old Feb 3, 2005 | 05:11 PM
NXRicky's Avatar
Put the purge as close as possible. Our nitrous solenoid has a port on the body for the purge vavle to screw to.
Ricky
Old Feb 3, 2005 | 05:16 PM
NXRicky's Avatar
Just the guy i have been needing to talk to. I have a question on particular parts. Can you get NX fuel rails and NX nitrous rails individually (the ones in the 90006 kit)? Yes I can sale you one rail at a time if that is what you want. and how much do they run? 100.00 retail Also can you buy the just the MAF end/nozzle by it's self--like if you have everything else and just want to convert to the MAF set-up.No it would need to be a conversion kit Because i have a friend that wants to do this, and he has just the basic set-up right now.
Let me know if we can help.
Ricky
Quickss96
Jan 29, 2016 05:56 PM
350350
14
Aug 11, 2015 12:03 PM
Strick
May 26, 2015 11:41 AM
CanadianZ
Advanced Tech
18
Oct 24, 2002 02:09 AM
lt4 fd
Advanced Tech
Sep 28, 2002 11:38 AM
