Question: How do you think this setup will sound? (Diagram)
Old Jan 31, 2005 | 03:23 PM
thewilldog's Avatar
Here's a diagram of what I plan to do w/ my 01 Z28. Everything is stock monsoon right now, complete with a blown driverside door sub.
http://www.ls1camaro.net/freehosting...%20Diagram.jpg
Looking for opinions on how this will work out. Is there anything being overlooked, or that will suck when I'm done?
Also, I don't know if I'll have to modify the harness to wire the tweeters. I guess I'll figure it out when I get all the pieces.
Background stuff:
Sub will be in a driver's side Subthump box.
Amp will be on a Subthump rack.
Alpine HU: 60W MAX x 4 V-Drive Power Amplifier
PUNCH 40i Power Amplifier Specifications:
Dynamic Power Rating -Measured @ 14.4 Volts
Mono into a 4 Ohm Load 160 Watts
Per channel into a 2 Ohm Load 75 Watts
Per channel into a 4 Ohm Load 40 Watts
Dynamic Power Rating -Measured @ 11.6 Volts
Elemental Designs 10" Sub - 11Kv.2 Dual 4
300WRms. - 0.4/0.6cF Sealed - 0.8/1.0cF Vented -
Old Jan 31, 2005 | 04:36 PM
shouldaboughtthez's Avatar
Re: Question: How do you think this setup will sound? (Diagram)
Don't recommend running stock 6.5" subs off of the monsoon amp and a 10" sub on an external amp. The 10" sub on the external amp will cancel out the 6.5" monsoon subs. When the 6.5" subs start to distort the 10" will not be. Also put a capacitor between the sub amp and the battery with the 130amp fuse within 18"'s of the battery.
Old Jan 31, 2005 | 08:18 PM
97FormulaWS-6's Avatar
That amp will not power that sub very effectively either; there's only one way to wire the sub and not fry the amp; 4 ohm stereo, thus only feeding each VC 40W rms; when they can handle 150Wrms. If you wire it for 2 ohm mono, you'll cook the amp, most 2ch amps are not rated for under 4 ohms of impedence mono.
Old Feb 1, 2005 | 12:06 AM
Alot of amps are rated to go 2ohm mono. Unless of course you are buying flea market crap...lol
Old Feb 1, 2005 | 06:28 AM
AFAIK NO RF amps are rated for lower than 4 ohm mono operation other than their Mono amps.
The only way a 2 ch amp will run a 2 ohm mono load is if each channel of the 2ch is 1 ohm stable; this is NOT the common.
Old Feb 1, 2005 | 08:52 AM
I have seen plenty of RF amps run 2ohm mono.
I don't use RF crap anyway.
"AFAIK" what the hell is this anyway?
Old Feb 1, 2005 | 11:02 AM
AFAIK - As Far As I Know
http://www.rockfordfosgate.com/liter...amplifiers.pdf
The Punch, and RF series are only stable to 2 ohms (in stereo operation); thus only stable to 4 ohm Mono
The Power Series is stable to 1 ohm (stereo operation); thus 2 ohm stable in Mono.
Therefore in his setup, his amp is NOT stable to 2 ohm mono...
And I haven't used RF equipment since the 90's... except for installing other peoples equipment.
Old Feb 1, 2005 | 11:20 AM
Me to, thats when they went to crap.
Old Feb 1, 2005 | 12:41 PM
thewilldog's Avatar
Ah, but that amp was bought in 1995, i.e. the 90's. It's nearly 10 years old, no big deal if I kill it.
Follow up: if that amp's no good, both due to the difference in monsoon power going to the 6.5's and the power going to the 10", what other options should I consider assuming the rest of the components are the same?
Old Feb 1, 2005 | 01:14 PM
you can keep your same configuration, just unplug the 6.5"'s
Old Feb 9, 2005 | 04:09 PM
CreatiVe2's Avatar
Or you can go with a JL 500/1 Amp thats stable mono to 1.5 ohm...
Old Feb 10, 2005 | 12:25 AM
thewilldog's Avatar
Thanks, but that's way more money then I intend to spend right now.
My speakers, head unit, sub boxes will cost less then that combined.
Sergio
Jan 27, 2016 04:27 PM
4586
Apr 27, 2015 06:08 AM
warmeck
Mar 22, 2015 10:28 AM
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
