Hot Cam'd 00 Z28 runs 13.70 @111.XX w/ a 3.0 60' What should it be?
Old Oct 9, 2002 | 11:25 AM
sfGi8nt's Avatar
I was just trying to "correct" a buddy of mine's E.T.
He has a 2000 A4 Z28. He has a Lid, 3.73's, Mac Headers, Off Road Pipe, Trans-Go, Loudmouth Catback, Hot Cam, PCM4LESS Tuning, Free Mods, and Street Tires
ANyways, we lined up one time at the track, and he ran 13.70 @ 111 w/ a 3.0 60'
He is hoping for a mid-high 12 when he puts on some ET Streets.
I was telling him that with the traps he is pulling, he should have a mid-low LOW 12 second timeslip....
does this sound right?
Just wondering if I am trippin or not!
Old Oct 9, 2002 | 11:44 AM
blkchevyz's Avatar
he needs some driving lessions... bad. with that mph it should run mid low 12s with tractions. a 3.0 60 foot it horriable. that should be around 2.0 on street tires.
Old Oct 9, 2002 | 11:56 AM
Kyle@CSS's Avatar
3.0. i thought i spun bad
South Carolkina
F&Y bodies
http://pub21.ezboard.com/bscfyb
Old Oct 9, 2002 | 12:11 PM
CASPER97TA's Avatar
it is possible to pull under 2.0 on street tires. that mph is no low to mid 12's. 111mph is low to mid 13's. i bet with traction he pulls a 13.3 at 111mph or 112mph. stock ls1's trap 105-107 all day and they run 13.3-13.7
Old Oct 9, 2002 | 12:50 PM
blkchevyz's Avatar
i ran a 12.39 @ 111 with a 1.82 60 foot.
Old Oct 9, 2002 | 01:07 PM
Ponyhntr's Avatar
No, 111mph will get you low 12's with a set of ET Streets. I have gone a best of 12.700 at 111.xx with a 1.82 60'. With a 60' in the 1.7 range it should be low-12's.
Old Oct 9, 2002 | 07:18 PM
Grover's Avatar
With a 111 MPH trap speed that is easily a mid 12 second run with traction.
Check my sig for my time.
Old Oct 9, 2002 | 07:44 PM
sfGi8nt's Avatar
Thanks guys. And yes, he has ZERO traction out there
And Casper, if LS1's trap 107 STOCK and run LOW-MID 13's, then why would you say that a 111 trap is only a low-mid 13?
You are WAY off buddy. But I'm pretty sure you meant something else, didn't you?
Thanks guys for the replys!
Old Oct 9, 2002 | 07:49 PM
Jerm93z28's Avatar
i got a 1.94 60' on street tires.... eibach pro springs, and m6, also.
jeremy
Old Oct 10, 2002 | 01:10 AM
AL SS590 M6's Avatar
Moderator
Well I just ran a 12.394 @ 109.26 with a 00 Formula A4
2 more MPH would put me at 12.20.
Old Oct 10, 2002 | 06:14 AM
rje's Avatar
rje
111 mph trap and only run mid 13's. Damn, if I couldn't drive any better than that I'd set the car on fire with me in it. Seriously, I run 11.9's at 111.xx.
Randy
Old Oct 10, 2002 | 10:16 PM
FASTFATBOY's Avatar
Well first off, why put a hotcam in a LS1?? What was he thinkin'?? His MPH is low for those mods, my buddy went 12.85 110 MPH in a stock 2001 M6 SS Z28 (had a whisper lid), another buddy went 12.15@111 with a 2000 auto Z28 , it had a 4000 converter, full length headers, cutout, whisper lid, LS1 edit, that was on drag radials. As far as 60 ft on real street tires, I have gone a 1.82 on radial T/A's in a 5.0 5 speed stang, so it is possible to 60 ft on streeters if the track is good( it was GOOD that day). Stock LS1's generally MPH in the 105/107 range for auto's and 108/110 for 6 speeds, it seems he is down on power a bit.
David
Old Oct 11, 2002 | 04:15 AM
sfGi8nt's Avatar
Originally posted by aggiez28
wow ive never seen a 3.00 60 foot before, did you take a nap at the light.?
it helps if you have tires on the rear wheels also.
j/k man but seriously thats beyond bad, a 2.0 is a bad 60 ft.
i mean you should be pullin 1.8s at least on a stock car w/ regular street tires.
just work on it and you will improve.
good luck
brook
Read it right buddy.
It's not my car, and it is also FAR FROM stock
Anyways, that was a couple months ago. Since then, he has got his PCM tuned from Bryan @ PCM4LESS and has a cutout now! He also picked up some ET Streets today, so we're in there FOR SURE now!
I told him he is good for a low 12 for sure. He's hoping for a mid 12. We'll see soon!
Thanks for the replies.
Old Oct 11, 2002 | 11:33 AM
Jerm93z28's Avatar
good luck
brook
2.0 is a BAD 60' for street tires?? to be honest i have never seen a car on street tires hit a 1.8x.... im sure its possible, i think my car with stock springs/reloc. brackets would be close... if it was an a4 i could pop off a few. but that would be considered a GOOD 60' on street tires!!! not the norm.
jeremy
Old Oct 11, 2002 | 05:59 PM
a_z28_vance's Avatar
David
Umm, there is a Hotcam for the Ls1's......
One of the local guys with a 99 SS runs 12.1 with a 112-115mph with his Hotcam and TTS headers and programming.
