Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Strange 12 bolt rearends on sale!
Old Jan 24, 2005 | 08:36 AM
tbyrne's Avatar
We have the Strange 12 bolts on sale through February 15th. This will give everyone plenty of time to place their orders and receive them in time for the 2005 racing season!
PRG210-PRGOP8 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars)
$2189.99
PRG210-PRGOP-14 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin)
$2189.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles.
The backing plates are only required for 1998+ cars.. $229.99
Orders can be placed online or by calling 1-877-482-9763.(1-508-636-0770 in MA).
Old Jan 26, 2005 | 03:45 AM
atljar's Avatar
Re: Strange 12 bolt rearends on sale!
Hey Tom-
Already have a strange 12 bolt. I need a new ABS sensor for the 3 channel setup. Can you please shoot me pricing.
Jared
Old Jan 26, 2005 | 12:20 PM
tbyrne's Avatar
The sensor is $60.
Old Jan 26, 2005 | 04:26 PM
atljar's Avatar
Thanks, i sent an email with order info since you were already closed for the day.
Old Feb 7, 2005 | 09:15 AM
tbyrne's Avatar
1 week left!
Old Feb 7, 2005 | 11:09 AM
atljar's Avatar
TTT.
Just wanted to say thanks, i got the sensor on my door 2 days after the order was placed. Top knotch as always.
Old Feb 7, 2005 | 11:54 AM
AlmostfastLT1's Avatar
very interested!
Old Feb 7, 2005 | 02:06 PM
tbyrne's Avatar
Your very welcome!
Old Feb 7, 2005 | 03:09 PM
hairbear's Avatar
Hey maybe you can help me. I already got a Strange 12 bolt but its for a LS1 and I have a LT1 so I need to get the LS1 stuff off and need LT1 stuff.
Old Feb 8, 2005 | 12:12 PM
tbyrne's Avatar
We haven't tried to put an LS1 rear in an LT1 so I can't give you a complete rundown if it is possible. I'm not sure if the LT1 backing plates will bolt-up to the LS1 rear. The calipers might also be different.
Old Feb 8, 2005 | 03:55 PM
atljar's Avatar
My 12 bolt is an ls1 style in lt1 car.
The lt1 backing plates bolt in fine, however the spacing isnt exactly right. You need to do lots of shimming to get the rotors centered in the calipers. Even after i shimmed and reshimmed, it still wore the pads unevenly. Finally switched to ls1 backing plates/calipers and all was well
Old Feb 9, 2005 | 08:02 AM
HungryT/A's Avatar
Tom,
I'd need a set (5pcs.) of replacement screw-in wheel studs for my Strange rear.
Can you give me a quote please?
TIA
Old Feb 9, 2005 | 03:52 PM
rpm4lalo's Avatar
So I can have 3.90's in a 12 bolt. Can you still use 3.90's if you use the super strength posi? Are those still avaiable?
Old Feb 9, 2005 | 05:25 PM
tbyrne's Avatar
Victor: I can check into the studs for you in the morning.
The 3.90s can be used with the Super Strenght posi. That posi is now standard in these rears.
Old Feb 9, 2005 | 06:12 PM
hairbear's Avatar
Thumbs up Re: Strange 12 bolt rearends on sale!
Hey thanx for the FYI. Guess I'll sell of the slotted rotors,hawk pads and get me some LS1 stuff. Did you have to chane brake lines as well? Reason I ask is that I have stainless steel ones all the way around and want to keep it that way
