Is this the heater core?
Old Jan 22, 2005 | 10:49 AM
Camm95Z28's Avatar
Just this morning, I started the car to go do some grocery shopping. I had no hot air coming out of the vents while in defrost. Is this a problem with the heater core?
Old Jan 22, 2005 | 11:31 AM
GreenDemon's Avatar
Re: Is this the heater core?
Assuming all other variables were correct, probably. But they usually go out slowly. Was the engine warmed up, and does the heat not work in any position?
Old Jan 22, 2005 | 11:46 AM
redzracing's Avatar
find both of the heater hoses that are goin into the firewall, after that (with car warmed up) grab the hoses
1. if one of them is hot and the other is cold then your heater core is stopped up
2. if both of them is hot and still no heat from any mode on your HVAC module, then i would say your heater core
3. if both of you hoses are cold then check something like a thermostat being stuck closed, or insufficient coolant in radiator
then tell me whats up with them if you need some help
Old Jan 22, 2005 | 12:49 PM
TraceZ's Avatar
Was there any air at all? Was it blowing cold air? The system defaults to defrost if there is a vacuum problem with the selector switch.
Old Jan 23, 2005 | 02:47 PM
If you are getting hot air, there won't be a problem with the heater core, but either with the vacuum, controls or mode selection doors.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
ducttape1975
Jul 10, 2015 06:29 PM
