trans question
Old Jan 21, 2005 | 11:25 AM
cammed_aro Z28's Avatar
trans question
i have a 94 z withe a 4l60E trans, and i was wondering if i changed the gears out for 3.73 if my car would shift properly without computer programming, i am not worried about the speedo being accurate. by the way the car is obd1 if that helps.
Old Jan 21, 2005 | 11:32 AM
30696bird's Avatar
Re: trans question
It will NOT shift properly.
Old Jan 21, 2005 | 01:59 PM
Brent94Z's Avatar
Super Moderator
Re: trans question
With the A4, you can have tranny damage by doing a gear change and not having the PCM programmed to account for it. You'll definitely want the PCM programmed accordingly.
Old Jan 21, 2005 | 07:02 PM
PonchoDude's Avatar
Re: trans question
Would'nt a hypertech programer do the trick??
Old Jan 21, 2005 | 08:25 PM
Capn Pete's Avatar
Re: trans question
When I've done the gear swaps from 2.73 --> 3.73 --> 2.73 --> 4.10, I've driven the car for short distances before re-programming the computer with the Hypertech, and the tranny still shifts like normal (the speedo just reads way off!). I believe that under normal driving, the tranny shifts more based on "load"? I never took the car up to WOT without re-programming, for fear that something could go wrong. I *think* that's where the programming is more critical, because the computer controls the shifts based on speed.
The Hypertech is simple to use, but for the same money, I think there may be better programmers out there that you can use to change other variables as well.
Moshbmx1
Feb 17, 2015 10:51 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jan 13, 2015 09:52 PM
capebuf
Jan 13, 2015 07:22 PM
Lederman1976
Nov 30, 2014 05:21 AM
