Rear End Help 97 Z28
Old Jan 21, 2005 | 10:57 AM
crazypurgatory's Avatar
Angry Rear End Help 97 Z28
I have a problem I guess I have a stock Torsen Differential in my car.
And it is toast.
What's my cheepest way out here.
I was thinking of going to a slavge yard and getting an open Differential from a camaro with drum on it.
Or I could always put the Differential back in but that would put more metal in it right?
I need some options here.
Thanks,
Chris
Old Jan 21, 2005 | 06:33 PM
94ZRiCeKiLr's Avatar
Re: Rear End Help 97 Z28
personally, i wouldn't skimp on the diff...if you put an open diff in, you're definitely going to miss the posi. a salvage yard may have a decent specimen for you, but you don't know what it's been through.
it's too bad SLP stopped selling those take-off Zexel-Torsens for $99...if i had known i would have bought 1 or 2 extra at the time...
in any case, if i were you, i'd try to save up the cash and get yourself a new heavy-duty Auburn or Eaton posi.
Old Jan 21, 2005 | 07:22 PM
Well I would miss the posi if it ever worked.
The year and a half that I have had the car it has never worked.
I took the Differential apart and it has no clutches in it at all.
Just two spider gears and two big gears with nothing behind them.
Thats why I think it is a Torsen.
Looks like I might have to buy a new diff.
The one in the slvage yard has 3.42 gears in it witch means it's on a series 3 carierr right?
I won't be able to put my 2.73 ring gear on it right?
And I don't have the tools to set up new gears or the know how right now.
Thanks for any more input,
Chris
Old Jan 21, 2005 | 08:17 PM
Capn Pete's Avatar
When you say the torsen is "toast", I'm assuming you mean that the internals actually broke, right? (one of the gears or something broken? ).
When you say that the "posi" hasn't worked in a year and a half, how do you mean? Since you've got the diff apart, and you've seen what it looks like with those worm gears and such, you do realize that a torsen operates differently than a true "posi" right? This thread from a few days ago has some detail about how the torsen works (there's a link halfway down that gets really technical).
For drag racing, you're better off with the auburn (or an eaton) posi.
Old Jan 21, 2005 | 08:42 PM
Chris
Like I said the inside has no clutches in it at all Just two spider gears and two big gears with nothing behind them.
With lines on the outside of the gears like threads that screw into the case.
And they look chewd up.
And I have always had the one wheel wonder.
I wish could be more clear about this
Hope that cleard it up a little.
Thanks,
Chris
Old Jan 22, 2005 | 07:04 AM
RE AND CHERYL's Avatar
I see those units all the time on Ebay for the same $99.
Old Jan 23, 2005 | 09:23 PM
Capn Pete's Avatar
Thanks,
Chris
Sounds like this differential. That's an Auburn, not a torsen.
Old Jan 23, 2005 | 09:30 PM
yep that's the one.
stock junk.
Chris
oldschool
Feb 9, 2016 09:21 PM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
