Turbo header diameter question?
Old Jan 19, 2005 | 07:00 PM
BigBird383's Avatar
What should the diameter be on a twin turbo exhaust manifold? 1 5/8?
1 7/8?
Old Jan 19, 2005 | 08:41 PM
Rodrigues's Avatar
Re: Turbo header diameter question?
I don't think the question is that easy but my guess is 1 5/8 for the most common application.
Old Jan 20, 2005 | 02:53 PM
94 NO TOP Z's Avatar
Looking around I think 1-5/8" will do fine too. You see some 1-3/4". There are Mustangs on the turbo Mustang board making 1400HP with 1-5/8" primaries.
Old Jan 20, 2005 | 06:15 PM
Rodrigues's Avatar
You want to use the smallest pipe before it becomes a restriction, in most applications 1 1/2" to 1 5/8" primaries are used. You can go too big, if you go with more than you need thats just more surface area on the tubing for heat to be lost.
Old Jan 21, 2005 | 09:31 AM
kcshaner's Avatar
1 7/8?
I did 1 1/2" on my single turbo, you will need no bigger then 1 5/8" IMHO
Old Jan 21, 2005 | 09:33 AM
kcshaner's Avatar
1 7/8?
BTW, smaller diameter headers will increase velocity and turbo spool......
Old Jan 22, 2005 | 08:56 PM
97WS6SCharged's Avatar
I think it's mostly dependent on the turbo specs and the displacement. 1 5/8 is probably good for a 350-396 motor, and 1 3/4 would probably be best suited to a 400+ CID small block engine. I'm using 1 5/8 tubes on my twin 383 setup.
Old Jan 23, 2005 | 02:31 AM
Rodrigues's Avatar
1 7/8 here for my twin project, 355 CI, I think i broke the rules
Old Jan 23, 2005 | 03:09 AM
Got any pictures?
Old Jan 23, 2005 | 09:52 AM
Bracket Boy's Avatar
I am using 1 7/8 tubes for my 388/91mm. The ID of the tube just fits over the port on my heads. Anything smaller and the tube would have been covering the port. Equal length is nice, but not really a necessary in a turbo application. I adopted the "just get there" philosophy from Young's Performance.
Just some thoughts.
Jay
Old Jan 24, 2005 | 01:09 PM
mongse_1's Avatar
I went 1.75 on my twins. I was told to take exhaust valve diameter & add 10%. That puts me right at 1.75"
Old Jan 26, 2005 | 11:51 AM
imnotfast's Avatar
The ones I built are steped 1 5/8 for 3.13 inches the 1 3/4 for 8.8 inches.
LeftoverChinese
Jan 14, 2024 03:03 PM
Highlander
Jan 12, 2020 02:13 PM
blac94Z
Jan 22, 2015 11:19 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
