Holley LS1 intake manifold?
Old Jan 16, 2005 | 07:20 PM
4birdman's Avatar
I'm looking at getting this manifold. I'm having a set of heads done for my business through Advanced Induction, so I'm hoping to get an intake that I can not only get ported, but I also have the ability to powdercoat red to match my red/silver scheme with the car.
Is this a good intake? I can get it cheap through my business and figured it was worth a shot.
Old Jan 17, 2005 | 11:07 AM
Greed4Speed's Avatar
Re: Holley LS1 intake manifold?
You can also port the ls6 intake too.
Everything I've seen the ls6 intake is better than the Weiand/Holley intake. If you need more runner volume get the LSX intake.
Old Jan 22, 2005 | 10:20 PM
Black98's Avatar
I have seen mixed reviews of this intake. Mostly, in the form of leak and minimal gains over the LS6. I would stick with the tried and true LS6 in most cases. These can be wet sanded and then painted. If you use N2O, the Holly would be benefical due to possible N2O backfire.
Old Jan 23, 2005 | 09:27 AM
4birdman's Avatar
Sounds good, and I can get a LS6 intake cheaper. Guess I'm heading that route! Thanks!
Old Jan 23, 2005 | 12:10 PM
robb4964's Avatar
Actually bird..check ebay . I have seen holley's go on there cheaper then LS6 intakes . from some reason People dont seem to bid on them to much as I saw one go for 250$ not to Long ago .
Old Jan 23, 2005 | 06:44 PM
CtRw's Avatar
Aluminum=Heat=Bad.
HarleyZ28
Oct 5, 2015 06:23 AM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
