Removing ABS
Old Oct 8, 2002 | 02:07 PM
POTENTZ's Avatar
Removing ABS
To all those with Ford 9''s
Does anyone know of all the fittings needed to delete ABS? I am going to start the project and don't know what I need. I am going to run the front brake line into my line lock and then into a tee that supplies each front wheel. Then for the back, I need to go into a Wilwood proporting valve and then splice into the rear line running to the back. I am not sure what fittings I need, like which ones are SAE or Metric. Also if anyone removed ABS, did you use stock master cylinder or did you use the Wilwood brake pedal/balance bar assembly and 2 single masters cylinders? Thanks
Boss002
Jan 20, 2016 12:17 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
CARiD
Jul 7, 2015 08:19 AM
