Ported MAF ends...gians?
Old Jan 11, 2005 | 04:51 PM
Cahill93Z's Avatar
i just picked up some Whisper MAF ends pretty cheap, any body know of dyno proven gians, maybe a couple of HP?
Old Jan 11, 2005 | 06:00 PM
teke184's Avatar
Re: Ported MAF ends...gians?
possibly for a short time, i've heard that the "learning" ability of the computer compensates for any gains and pretty much returns to normal
who knows...
get it dynoed
Old Jan 11, 2005 | 11:14 PM
LSUxBlake's Avatar
They really only provide gains on cars that are running rich, because they actually let unmetered air through. If your car is running lean, they will cause problems.
Old Jan 12, 2005 | 05:23 PM
Greed4Speed's Avatar
Try probable power losses and detonation.
Go to a decent tuner and they'll tell you to stick with your stock MAF.
Old Jan 12, 2005 | 07:15 PM
Cahill93Z's Avatar
ya i've heard now my car will run worse? when i go to the track ill install them and see if i pick anything up
Old Jan 12, 2005 | 09:45 PM
XKnightRider's Avatar
On a totally stock car they will gain you a FEW hp just cuz it leans you out. When I had Lid/filter and then added MAF ends my car just threw codes and detonated over 5K RPM. As most tuners will and have told you they are a lost cause, sorry. No one in my club runs them, with the heat out here in AZ they don't do well
Old Jan 13, 2005 | 03:57 PM
Cahill93Z's Avatar
how about in the future, if i'm getting my car dyno tuned could i throw them on and they can just make the car run more rich?
Old Jan 13, 2005 | 04:14 PM
LSUxBlake's Avatar
First of all, they make the car LEAN, not rich. Secondly, I dont know any tuner who will tune with them on, mostly all of them want stock MAF's.
Old Jan 13, 2005 | 05:15 PM
Cahill93Z's Avatar
i know that was why i siad more rich becuase it makes the car run more lean, so make it run moe rich to compensate
Old Jan 14, 2005 | 08:53 AM
LOL...I've heard tuners tell people to come back when they have a stock MAF.
Old Jan 14, 2005 | 10:05 AM
Cahill93Z's Avatar
well that was a waste of $40 anyone want MAF ends?
Old Jan 14, 2005 | 08:51 PM
mrr23's Avatar
i had VHP install their MAF ends and dyno'ed it. here's the results. http://www.stealthram.com/familypics...mafhousing.jpg
gained 2 peak hp and almost 8 hp after peak. is it worth $100.00 new for such little gain? only if you are going to stay in the upper rpms where the benefit is. they have been on since april 04. no ill effects because of it.
Old Jan 15, 2005 | 01:11 AM
V6toZ28's Avatar
Two things ... did you do an AFR and what do you think the PCM is going to do with miscalibrated MAF readings when the temp isn't 69 degrees?
Old Jan 15, 2005 | 01:40 AM
atljar's Avatar
I know some pretty fast/very streetable (10 sec NA 6 speed 346ci cars) that are running MAX ported zo6 mafs. Yes it really throws off the tune, but as long as you arent doing mail order tuning, you should be able to get everything squared away making more power, and also safely.
Old Jan 15, 2005 | 12:04 PM
mrr23's Avatar
they read o2 readings from the PCM when it was done. before readings were 980-1002 mV. after was 890-910 mV. it'll do the same thing it's been doing since i installed it. run and drive everyday. no pings, no rattles, no knock even on 175 n2o.
what do you think a PCM will do if you dynotune in 69* weather then go run in 90* weather?
