Do blower cars need stiffer valve springs?
Old Jan 3, 2005 | 08:48 PM
hellostop's Avatar
Assuming I hold my redline to 5250 per prochargers's instructions for installing a d1sc on an lt1, are my factory valve springs ok? Or does boost reduce the spring's ability to control the intake valve? exhaust?
Old Jan 3, 2005 | 09:09 PM
trtturbo's Avatar
Re: Do blower cars need stiffer valve springs?
You might as well do it. It will be hard to hold the rpm's that low when the boost is building. Go ahead and put better springs to get the valves shut fast!
Old Jan 3, 2005 | 09:13 PM
hellostop's Avatar
My rpm's should stay reasonable as I had my pcm tuner set my redline to 5200. But do blown motors NEED stiffer springs due to boost??
Old Jan 3, 2005 | 09:14 PM
rskrause's Avatar
Moderator
IMHO, yes. Another 15-20lbs of seat pressure makes a lot of sense to me. I have no data to support this, but it seems logical to me at least on the intake side. The area of the intake valve is >3sq. in. With 10lbs of boost, there will be ~30lbs of pressure on the backside of the valve. More seat pressure will counteract this. OTOH, I see no reason for a spring with a higher rate.
Rich
Old Jan 4, 2005 | 09:44 AM
Pro Stock John's Avatar
If you are doing a supercharger, and have a stock internal LT1, I would upgrade the valvesprings.
I think we need more spring pressure, but sometimes its a pain in the *** to spec out springs.
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
