sylvania silverstars fit 4th gens??
Old Jan 1, 2005 | 08:34 PM
blackztpi's Avatar
I'm looking for some silverstars that will fit my 94. i can't seem to find a certain part number. ??? thanx
Old Jan 1, 2005 | 08:40 PM
Z28barnett's Avatar
Re: sylvania silverstars fit 4th gens??
They don't make them, you have sealed beams.
You can buy a set of 9005 & 9006 bulbs and glue them in.
Old Jan 1, 2005 | 08:59 PM
blackztpi's Avatar
they don't have sealed beam lamps either? how hard/relaible is it to glue them in? thanx. i only want to replace the low beams
Old Jan 1, 2005 | 09:54 PM
Z28Nut's Avatar
I just checked out Sylvania's site and they don't list the H4351 ( low beam ) or H4352 ( highbeam ) under Silverstars. If you want to see some other ideas, check out Sam95zNoTop's thread here:
http://web.camaross.com/forums/showthread.php?t=62272
I think there were some posts and or links about modifying the stock sealed beams with better bulbs.
Old Jan 2, 2005 | 05:30 PM
lt1zpwr's Avatar
sylvania makes some low/high beam headlights i have the low beams and they are hella bright, they are almost as brite as my stock hi beams u should check em out
Old Jan 2, 2005 | 09:43 PM
DiabloGT's Avatar
what model # in autozone are they for high and low? and do they fit the hella ff75/ or what are the best bulbs for the ff75?
thanks
Old Jan 3, 2005 | 06:27 PM
blackztpi's Avatar
yeah, i'd like that part number. thanx
Old Jan 3, 2005 | 10:01 PM
Z28Nut's Avatar
Here is Sylvania's Silver Star product line-up:
http://www.sylvania.com/ConsumerProd...r/ProductLine/
I don't see H4351 or H4352 listed. They don't make Silver Star replacement headlights for 93-97 Camaros.
If you want better lighting, you will have to remove the factory sealed beam system and custom mount modern technology high-performance lights. Hella FF75s are an excellent fit and look very close to stock (but better -- they have a clear lens and it looks much better than stock). Hella 90mm projectors (only the lowbeams are true projectors, the highbeams are free-form reflectors) are harder to fit but are DOT legal. Piaas are another excellent choice and of high quality, though more expensive than the Hellas. These are all modern technology free-form reflector or projector lights, not antiquated sealed beams.
There just aren't very many options to plug and play with our style of headlights.
Old Jan 3, 2005 | 10:10 PM
Z28Nut's Avatar
DiabloGT -- The FF75s take a h7 halogen bulb and are available from 55w to 100+w. The FF75 is a driving or fog light that completely replaces the factory sealed beam assembly (I suggest driving beam pattern for either high or low beams). It is not a direct replacement for the sealed beam but needs all the stock mounting stuff to be removed and custom brackets made -- they are easy to make.
Dec 31, 2014 02:21 PM
Chris 96 WS6
33
Sep 3, 2002 09:48 PM
JasonD
Jul 15, 2002 02:17 PM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
