Pro 5.0 deosn't center itself
Old Dec 12, 2004 | 08:51 PM
speed_demon24's Avatar
Angry Pro 5.0 deosn't center itself
I just got a pro 5.0 shifter because I'm doing a T56 conversion, and the shifter doesn't center itself when its in neutral. Does anyone know how to fix this?
Old Dec 13, 2004 | 06:24 AM
97FormulaWS-6's Avatar
Re: Pro 5.0 deosn't center itself
Do a search for "Spring pro 5.0", sometimes I've heard of some weak spring issues with the units before. Basically you can take the shifter apart with 4 screws and shim or replace the springs to get the return-to-center function stronger.
Old Dec 13, 2004 | 08:25 AM
I did the shims and I can either get it to center from the 1-2 gate or the 5-6 gate, not both. I felt the hurst with the short stick in my dads trans am and that thing has springs that are 5x stronger.
Old Dec 13, 2004 | 11:30 AM
That is odd.. try contacting the company, they are known to be very helpful. I've had no issues with mine in 4 years, still works great, even W/O the shims.
Old Dec 13, 2004 | 06:35 PM
I found a spring with thicker coils so I just cut that down and put a shim on one side for the 1-2 gate so it has a stronger force than the 5-6 gate and now it centers itself perfectly.
LT14LIFE
Nov 15, 2015 06:22 PM
WobblySausage
Oct 7, 2015 02:44 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
