Need High beam wiring harness help.
Old Dec 12, 2004 | 06:06 PM
Chris 96 WS6's Avatar
I installed H4 headlights last year as an upgrade. The Lows worked fine but the 100w high beams burned out a ground I believe in the stock harness.
I'm installing a relayed headlight harness from Painless wiring and all is well except the highs don't work still. I think since that ground is bad there's not enough juice to switch the relay on.
With the high beams turned on, you can here a wire shorting somewhere near the pass. headlight, but I can't find the exact location.
Does anyone have a schematic or otherwise know where the ground for the high beams would route on a 93-97 Firebird?
Old Dec 12, 2004 | 06:08 PM
Re: Need High beam wiring harness help.
Or is this a power wire issue? Do high/lows share the same ground?
I should mention the parking and fog lights work fine on low, but on high beam, they flicker in unison with the shorting/crackling sound. I think its a wire frying because you can smell it.
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
siguy
Nov 27, 2014 10:07 AM
$hawn
Aug 3, 2002 04:59 AM
CobraEatr
Jul 23, 2002 06:32 PM
