BLM Locker Issues on a 93 SD car
Old Dec 8, 2004 | 03:59 PM
Fastbird93's Avatar
I downloaded BLM Locker, but haven't managed to get it to work. I keep getting a "file size is too small" error, and it won't let me do anything.
All my files are tunercat 32kB .bin files.
Anyone have any idea??
Old Dec 8, 2004 | 04:29 PM
Gimpster's Avatar
Re: BLM Locker Issues on a 93 SD car
Well, unless the blocker is for 94+ Cars I dunno.
Where did you get the blocker anyway and I'll try it.
Old Dec 8, 2004 | 04:32 PM
Fastbird93's Avatar
It shouldn't be for just 94+, I saw a couple of posts about it and it said any Tunercat or LT1Edit file.
http://carprogrammer.com/WOT_BLM_Locker/ is where I got it. I do believe that's the original writers website too.
Old Dec 8, 2004 | 06:12 PM
turbo_Z's Avatar
All my files are 128kb and have always been that size... maybe SD is different.
Old Dec 8, 2004 | 06:53 PM
Fastbird93's Avatar
That could very well be the problem.
Old Dec 8, 2004 | 10:36 PM
Dan K's Avatar
I've never gotten it to work on a DA3 car.
Old Dec 8, 2004 | 11:03 PM
Gimpster's Avatar
Says its for GM 16188051 which is 94/95 LT1 (flash). The 128k rom size an earlier poster confirms that. I'll take a peek and maybe can make a patch for you. I'm sure all this patch does is force load the RAM byte for BLM to 128. Assuming you know which RAM byte it is.. thats no big deal.
Old Dec 8, 2004 | 11:23 PM
Gimpster's Avatar
Fastbird93, please test this rom:
http://cow.pasture.com/~bix/93-BNXF_...379-128BLM.bin
I think I isolated the BLM stuff and locked it. That is an otherwise STOCK rom from my automatic 1993 Z28 (I did change the PROM ID to 6969), so please change / import whatever you need to make it run properly with your TunerCat.
I would test it, but I have my intake manifold off and tranny out
If it works, lemme know.. I'll write a lil patcher for it like that guy did.
If it doesnt work, back to the drawing board! Gotta show the 93's some love, I don't like MAF's anyway.
Old Dec 9, 2004 | 08:14 AM
Fastbird93's Avatar
I looked around to see what you did, and couldn't find it. Care to share???
I've got to drill my BBK tb for a bleed hole today or tomorrow, and then run the car with the tune that's in it first, to see if that corrects the split BLM issue. If it does then I'll be playing with the tune, but if it doesn't it's going to be back to the drawing board. I just don't want to start messing with things until I KNOW what the cause of my 100% split BLM issue is.
Old Dec 9, 2004 | 12:04 PM
Gimpster's Avatar
I hear ya, ... the whole BLM locking is pretty band-aid from what I've been seeing. Basically I dasm'd a 94-95 ROM after applying the blocker (it only made 2 changes) and found similar code within the DA ROM.
Changes are @ 48CBh, changed to 27 00 & 4828h, changed to 27 00
Stock Snippit:
48C2: 14 61 08 BSET L0061,#$08 ; BLM?
48C5: 7F 01 4A CLR L014A
48C8: B6 01 47 L48C8 LDAA L0147
48CB: 2B 02 BMI L48CF
48CD: 86 80 LDAA #$0080
48CF: 13 60 20 03 L48CF BRCLR L0060,#$20,L48D6
Changed:
48CB: 27 00 BEQ L48CD
48CD: 86 80 L48CD LDAA #$0080
48CF: 13 60 20 03 BRCLR L0060,#$20,L48D6
Still a little confused as to how that works on the EE stuff, but I'll figure it out... anyway thats how he did it.
calaban
May 18, 2020 06:43 PM
PCLZ28
Dec 24, 2015 05:19 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
