Ford 9" or Moser 12 Bolt??
Old Oct 6, 2002 | 03:36 PM
BOWTYDE's Avatar
What one is better? I'm looking for some solid performance. I want to put 4.10s in it and run some slicks at the track. I have a 100 shop of NOS right now and going to do some engein work soon.
I have heard that the for 9" is easier to install. Is this true?
Old Oct 6, 2002 | 04:17 PM
JackZ.Twenty8's Avatar
The Ford is by far a better rear. It will hold more horsepower than the 12 bolt. Price is really the same, so I will be going with the 9" too!
Old Oct 6, 2002 | 07:18 PM
Freak's Avatar
OK, in order to determine which is better you MUST define better.
the 9 does handle more power. this doesnt magicaly make it better
here is a quick rundown of both
9 inch
stronger
heavier
less efficient
every gear ratio in you can think of available
generaly noisier
MUCH easier to change gears in.
can be had with ABS/ traction control, but not with ABS only cars.
no C clip eliminators needed
12 bolt
strong but not as strong as the 9
slightly lighter
more efficient
usualy quieter
serious PITA to change gears in
can be had with ABS or ABS/ traction control.
C clip eliminators needed, some tend to leak when exposed to high lateral loads (hard cornering)
I chise the 9 inch for a number of reasons, not the least of which is the ease of gear changes. that doenst make it better than the 12 bolt. YOu have to decide what is important to you.
I have no clue about the 12 bolt, but I was able to install my 9 inch in the car completely by myself. The 12 bolt might be harder because I put the housing of the 9" in without the center section, this accounts for a lot of weight, and you cant do that with the 12 bolt. you could remove the carrier and even teh pinion, but then you run into the PITA that is known as gear install on a 12 bolt.
either will be plenty strong provided they are set up correctly
Old Oct 6, 2002 | 07:40 PM
Ken S's Avatar
a 12 bolt can be set up with the bearings on the axle's ala 9" style so no C-clip eliminator is needed to keep the axles in.
for roadracing, a 9" has a few more posi options since its more popular..
9 inch
stronger
heavier
less efficient
generaly noisier
12 bolt
slightly lighter
more efficient
usualy quieter
Old Oct 6, 2002 | 09:54 PM
NED4SPD's Avatar
Which is better for guy who drag race and road race??? I was lookin at the 12 bolt cuz I was told it was better for road racing. I would drag race more but I would like a all around STRONG AS HELL rear end.
Old Oct 6, 2002 | 10:20 PM
supersp0rt's Avatar
it also depends on what spline axles you get as well. moser offers splines well into the 40's...
Old Oct 7, 2002 | 08:19 AM
Ok, by better, I mean stronger. Much stronger. I have a buddy who built Mustangs using nothing but 9" and he is quite confident when he says they are stronger.
Old Oct 7, 2002 | 06:18 PM
BOWTYDE's Avatar
I'm think I going with the 9". Any suggestions on what else I should get this it? What posi, axles? What else will I need? What i'm I looking at to install one of these?
Old Oct 9, 2002 | 12:31 AM
CobraKilla's Avatar
My 98 TA has a Moser 12 bolt, see sig...My 92Z is getting a 9 inch really soon, I like them better and I can change the gears in a half hour when I need to with the 9inch...
HarleyZ28
Oct 5, 2015 06:23 AM
ddr698
Jan 9, 2015 10:05 AM
Wicked
Aug 22, 2002 12:37 PM
kev93z28
Aug 19, 2002 12:48 AM
