forged pistons for stock bore ls6
Old Dec 7, 2004 | 05:19 PM
exolution's Avatar
I'm building up an LS6 engine. I can't seem to locate any stock bore forged pistons for it. JE/SRP and everybody else I've tried would have to do a custom forge, and that's too expensive..
Does anybody know of a set of forged pistons for a stock bore LS1/LS6?
Thos project needs to be finished by the end of next week, so time is definitely an issue.
Old Dec 7, 2004 | 08:35 PM
natesiy's Avatar
Re: forged pistons for stock bore ls6
If you bore it out to a 3.905" bore, there are many pistons that will fit.
The sleeves won't take much more than that.
Check Wiseco, Ross, Diamond.
Old Dec 7, 2004 | 09:27 PM
exolution's Avatar
It's looking like that's what we're going to do. Do you know what the stock bore, and maximum allowed bore for those sleeves are? I need some of this information to guarantee I get the right pistons/bore specs done. Turns out boring an engine is significantly less than I thought. Machine shops are the ****.
On that note, what are the specs for the head bolts? I'm trying to go with ARP, but I'm not sure if I should get LS6 or LS1 bolts (I hvae an LS6 block, with LS1 heads), and what length they are. The tech told me there's a kit with 11mm length bolts all through, or variations of lengths in a kit.
Old Dec 9, 2004 | 04:45 AM
AL SS590 M6's Avatar
Moderator
LS6 and LS1 blocks are the same as far as the head bolts go. And most of the bolts are a couple of hundred mm long. Three lengths and two diameters. Thunder Racing lists 113-134-3609 ARP LS1 Hex Head Bolt Kit $139.64
Old Dec 12, 2004 | 11:45 AM
pekkaz's Avatar
Mahle and Lunati offer off the shelf forged pistons for stock bore. Check Texas-Speed for Mahle.. I've seen Lunati at least at SDPC & Tbyrne
Old Dec 14, 2004 | 04:14 AM
natesiy's Avatar
ARP stud kit number is 234-4110
Just bought a set, sitting rite next to me.
Old Dec 14, 2004 | 04:21 AM
Moderator
Yep, so now he has the numbers for studs or bolts. I went with studs myself.
Old Dec 14, 2004 | 09:56 PM
Goody_Seven's Avatar
Probe also makes pistons for stock bore LS1s
Old Dec 14, 2004 | 11:32 PM
pkincy's Avatar
On that note, what are the specs for the head bolts? I'm trying to go with ARP, but I'm not sure if I should get LS6 or LS1 bolts (I hvae an LS6 block, with LS1 heads), and what length they are. The tech told me there's a kit with 11mm length bolts all through, or variations of lengths in a kit.[/QUOTE]
Your tech is correct. PN 12498545 is the 97-03 head bolts in a set. The 04 set is all the same length and is a different part no. You probably have a block that is 97-03.
Use the stock bolts for a NA build up. You will need the ARP for power adders.
Perry
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
Killer94z
Jan 13, 2015 12:06 PM
Queens94z28
Nov 20, 2014 06:03 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
